yeah, imagine all the gunk and shit yu'd get on the iphone from having it next to your ear all the time. Im happy with my phone. If i had an iphone, and it broke/got stolen, then i lose sms, calls, gps and music, the 4 things i use the most, all in one device.
So, anyone wanna but an old school (original) iPod nano? ill even leave my electro/house songs on it :thumbsup:
Edited by Damo_R34
Mike, the beauty of the internet! I downloaded it via torrent. Trust me, was well worth the download. Episode number 11x04, here's the EXACT file name to help you all...
top.gear.s11e04.ws.pdtv.xvid-river
Don't get me started on the iPhone, overhyped piece of shit as far as I'm concerned, as is the case with many Apple products, people just buy them to "look cool" and pay a premium for that coolness
Edited by heslo
not sure but didn't someone on here with a rb25 in a red r32 ran 280kw with stock injectors? i think his name was simon or something
If it wasn't safe it would have popped by now being an unopened rb25, considering the workout that car gets from simon, Im sure simon wouldn't have done this if he didn't think it was safe. Jeff from The Speed Lab tuned it.
iPhone=marketing bullshit. waste of money. ill stick to my bulletproof nokia and my creative zen. no way i will infect my computer with iTunes bullshit.
MMM still loving my Sony Ericsson K750i.... does everything I want except change the channel on the TV hehe
-D
hey... looking at turbos for my rb25 when she arives!!
i have been looking through slouches GB and came across the 3071r and 2871r..
which would be the turbo to go for and wat housings would best suit! looking for response and 280ish even 300kw fo a later date!
http://www.skylinesaustralia.com/forums/Ga...86-t210306.html
cheers
what do people think of these? going with my new slotted rotors.
EDIT, stupis link wont work!
heres some of the desciption:
QFM (Queensland Friction Material) Brake Pads are AUSTRALIAN MADE & OWNED
They have serviced the Automotive Trade for over 17 Years
these brake pads are rated at 750 Deg C.
they are designed for extreme use from the Street to the Track
K750 brake pads will perform from dead cold to 750 Deg C.
If you want the ultimate in performance & everyday durability these are the pads for you.
Edited by craig R33
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
