Luke's not the only one that's just bought some goodies!!
Thanks to Darron from Just Jap.....friendly guy and very good service.
Also got Joel to hook me up with a Gates belt so just need a waterpump now........anyone here know where to get a good price on one.
Might be giving you a yell soon Ryan :(
hehe no worries pete! just holla my way!
sled as ryanrb25 about water pumps.. he got me mine!!
And yea as Luke said, for a 26 id pay the extra and get an N1 pump, With high revs standard ones tend to cavitate as N1's dont.
yeah thanks Ryan, as soon as I get my act together I'll track you down.
I'm definitely leaning towards the N1 if I can get one for a reasonable price but I'm not keen on paying $300 or more when a stockie should be a fraction of that price......I knew of a place overseas that were selling N1's for approx $200 but can't find them anymore.
Now apparently RB's don't use gaskets for their waterpumps.....huh!!? What do you guys put them on with?
I usually buy water pumps from sprints for around 70 bux, Genuine standard ones from nissan are about 180 or so onwards. They all come with gaskets, I also use HOLIMAR gasket bonder on the gasket aswell for safe measure.
Edited by Ryanrb25
all the gaskets i have got from Nissan haven't been that expensive. Having said that the R200 diff gasket i got a quote for the other day was $97.
So is Unley Nissan saying that there is no gasket for RB26 water pumps or just that you have to buy it seperatley?
EDIT!!
R34 GTR's are on the "NISSAN FAST" that I have and it only has a listing for liquid sealant with the water pump, no gasket. So that answers that question.
Edited by D_Stirls
Hylomar?
I use that gear on all gaskets.. mainly plenum, inlet etc. Even used it on problem IC hoses that blow off. :(
But nothing wrong with silicon for the water pump gasket/thermostat housing. They are just a bastard to get off next time you go to service it.
Its a waste.. You will then have to worry about throwing too much oil in to the head and how to get it back again.
The N1 pumps are difficult enough to control and require restricting of the oil that flows to the head.
Stick with the RB25/GTR std pump or if you must go for the N1. RB25det and GTR pumps are the same.
http://page11.auctions.yahoo.co.jp/jp/auction/n61626351
thats the only n1 pump my mate could find. roughly $220 to buy then around 80-100 to get it here i reckon.
Just spoke to my mate who can get the N1 waterpumps for a bit cheaper than that including freight from overseas.
We're talking under $300 for 1 and as low as $260ea for 4 or 5.........anyone local interested?
Either way, at that price I'm going to order one cause I don't think we'll be able to find them cheaper anywhere else......and as stated by Ryan they don't suffer cavitation issues at high rpm and apparently flow better at lower rpm due to the bigger impellar with less fins.
I could be, depends on how soon you need to get cash? Gonna be tied up for the next few weeks...;\
-D
Ben that would be OK....it'll take up to a couple of weeks to arrive.
For peeps that I know from here I would be happy to take your word as confirmation and I'll order them either tonight or tomorrow and pay for the lot up front.
My new tie rod ends has arrived awesome :ermm: anyone fitted these before? Should I fit them myself I'm not sure because getting the adjustment exactly dead-on on both side looks to be a pain or should I have some suspension place do it so they adjust it and get an alignment done aswell?
on the way to work this morning i noticed my tyre was flat but becuase the insurance company in taking its sweet time to fix my car cant get the jack and spare out so had to keep driving or limp (10 min) to take locky to school and myself to work and when i got to work i noticed the tyre is about 15cm off the rim now :ermm: and i cant see where or why its flat
Edited by Bunny33
My new tie rod ends has arrived awesome :D anyone fitted these before? Should I fit them myself I'm not sure because getting the adjustment exactly dead-on on both side looks to be a pain or should I have some suspension place do it so they adjust it and get an alignment done aswell?
Put the tie rod ends on yourself. Use a tape measure and measure roughly how far screwed on they go. Then limp your car to a wheel aligners.
:ermm:
Kell, sucks about the tyre. No nails or leaks you can see?
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
