yeah he is where i got the idea from :blink:
the Blitz 555's are $690, will i need an aftermarket fuel rail for them or new regulator?
Don't be WEAK!!!!
Go for a set of 800's so you can tune it for E85 as its now available in SA and soon to be rolled out everywhere. :)
Don't be WEAK!!!!
Go for a set of 800's so you can tune it for E85 as its now available in SA and soon to be rolled out everywhere. :blink:
haha Joel loves his E85. my worry is the availability, if im running close to empty, and there aren't any e85 servos around?
Don't tune for it just yet.. But at least you know you will have the head room in the injectors when your ready to. :D
A set of sard twin spray 800cc's pull up fine and return stock economy. Don't buy single squirter's they are crap under 2k.
You need around 35% more injector with E85. So for ~300rwkw you will need ~700cc injectors with E85.
Depends on the dyno but 550's generally hit 80% at around 300-310rwkw. + the E85 as you can crank some timing in to it and it just won't ping will make another 30rwkw odd.
Just sucks 34 injectors are so expensive in that size. ;)
yeah he is where i got the idea from :D
Mate, Nismo gear goes straight in without any different plugs, fuel rails n all that bullshit...
Cubes, whats the go with E85 eating at your fuel pumps, lines, injectors? Im curious!
im now officially an unemployed bum ;)
but i must say working for the gov was the best job i ever done
best day working there was handing out free suncream to people at the big day out giving me a free ticket into bdo and getting paid my normal accounts wage while there :D boo ya
feel free to let me know if you hear any accountant type jobs going.
Edited by Inline 6
Yeah i read that too Ryan, apparently even the fuel tank should be changed the stainless steel, and you have to remove all rubber, foam etc from the fuel setup.
bah its load of crap. :D
Ethanol actually cleans. Not quite as good as water injection but damn close.
Unless you leave it in your tank for 1+month only then does it begin to absorb water.
Unless you have an aluminium fuel tank you don't have to worry. ;)
Bosch fuel pumps are designed with ethanol in mind.
The 'only' issue E85 has is with 'old' fuel line.
I've replaced my fuel hose from the tank to front with suitable hose from pirtek cost me a total of $40. These cars are 10+ years old now its worth while replacing fuel hose regardless of fuel especially when base fuel pressure (36-40psi) + boost (20psi) = up to 60psi of pressure running through 10+year old often surface cracked fuel hose = disaster waiting to happen.
Cubes, whats the go with E85 eating at your fuel pumps, lines, injectors? I'm curious!
Dino fuels leave deposits, so when you change to Bio fuel it will clean out the system. Its a food idea to replace your fuel filters regularly for the first few thousand k's (ie at 2K and again at 5k)
As for fuel lines, if you still have the original rubber ones replace them (they are overdue anyway), and if you have replaced them in the last 2 years you should be fine. Its the same argument for E85 as Bio-Diesel, much of it is scare tactics, other bits are common sense.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
