just got back from uni snow trip 08 :D was awesome
never snowboarded before but moto for the week stolen from T Hawk was Go Hard or Go Home
hits
180, method grab (pics to come from someone else on the trip as my cam sucked n i fogot to bring the sd card)
misses well could call em hits to
lesson 1, dont place your leg behind the binder on the snow board when leaving the ski lift, slope go's up chair comes down leaving your leg jammed between feeling like it may break if something else dosnt give
lesson 2 when your friend boots it off before you do not overcook it trying to catch up, leaves me catching the wrong edge of the board and hitting the back of my head followed by the front. i couldnt see properly for 10min and had a headache for the next 2 days :D not to worry i kept bording
note this is the 2nd hit on the front here in the pic, lucky i had contacts in and no goggles on, it was also joked about the previous day i was the most likely to get injured :P
nissan sponsership deals on this mountain, i thought the 1st instructor was a nissan fan but then i realised they all had the same jacket with mt hotham written on it aswell. most people had subaru's there so i guess it aint working for nissan.
my good friend mr frostafied (i didnt build it as it takes forever to build 1)
highly recommend a trip like this to all, had f all sleep all week n just about all my body stings but it was worth it
the nice view and cliff edge (on the right in pic) some fool lost their snowboard down :D also spotted 2 people ski down it and come hiking back up 4hours later :) they have lifts in other spots guys they wernt even going for the snow board.
Edited by Inline 6
just got back from uni snow trip 08 :) was awesome
Hehe nice, hotham summit chairlift, I know it well. I'm gonna be renting a place on dinner plain next year :P Should be good
-D
yeah they had heaps of other 1s but they all said the pajero or some other nissan that i don't know started with m no doubt some sort of 4wd.
unfortunately stealing them is not possible unless you wanna climb the pole covered in ice with some wire cutters
2points to dohmar for spotting it was hotman, shoulda got a pic of this huge mt hotman writing in the snow people made looked awesome but as i said no pics for me :)
hopefully 1 of the other snap happy uni students got it
Edited by Inline 6
Yeah, massive rash on the other rims, thats a good rim! I'll grind out the rash at work then get them repainted, then they will look sweet :down:
please dont say those are the ones that are in the forsale section from psyco?
isnt it better off porting the old manifold then buying a new one? Pretty sure Matt (boostedR) was saying that stainless tend to crack and wont flow much more then porting a standard one.
i tig welded for 4 years so cracks dont bother me, cracks are usually because alot of manifolds aren't gusseted, wall thickness and penetration of welds. I got it really cheap so i dont really mind lol...its more of an experimental thing rather than chasing more power..
Edited by Ryanrb25
high mount or low mount ? (the stainless steel one that cracks)
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
