very, very nice. something about leather just freaks me out a bit tho, like im gonna get tied up and tortured. would much rather see her pulling a little g on :wave:
watch it closer, and you'll see it becomes a G !!!!
wooot
:wave::)
haha i was wondering what you would say
Yeah pokie is there a congratulations in order?
yeap guess so lol
I'd be shit scared if the missus fell pregnant. Not to say I wouldn't keep it but just not ready for that at this stage of my life
i'm not exactly ready for it believe me but yeah, it could be fun and stuff, i'll find out eventually.
i have my 1st appointment at the Lyell McEwin Hospital on Friday, they put me in early coz of the situation
LOL my mum already bought a freakin jumpsuit thingo for it, i wasn't to happy about it but not much i could
do to stop her. my brother said he's gonna buy it Ford shoes or slippers
thankies Tangles ;)
yeap guess so lol
Sounds like you're trying to convince yourself Amanda......Congrats anyway.
Is the dad hanging around to be part of all this?.............don't answer if you don't want to.
nope he's being an ass and trying to convince me to kill it
when he 1st found out he was alright but then he said he wants nothing to do with it or me
but that's alright i don't really care. his parents are still gonna be involved though which
i'm ok with coz i don't see why they should miss out just coz he is
sounds like you're better off without him....show him the door and sink your foot in his ass if he wants you to kill it!!
yeah i am better off without him, i don't need him anywayz, i have my family
ahh, that sucks. best of luck Amanda!
it surely does, but it'll get better eventually :)
id be happy if my missus was to fall preggers.......just have to slow down on the mods on the 33 :huh:
I'd be happy if my missus was preggers too. My ex-wife never succeeded in that department ... so I've almost given up on the idea. But there's always some hope.
Its always good to hear stories of people who deserve babies ... then there are those who don't. I've known many people (myself included) who would give up all for a family, but its never happened.
Once again ... congrats Pokie! :)
Check out this mint 32 GTR
[email=http://cgi.ebay.com.au/1994-Nissan-Skyline-R32-GTR-White-5-Speed-M-Coupe_W0QQitemZ120284857195QQihZ002QQcategoryZ35227QQssPageNameZWDVWQQrdZ1QQcmdZ
iewItem]6000km R32 GTR[/email]
EDIT* ^^^ stupid link
Edited by DSTROY
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
