congrats on the purchase Ruby, well done :P
any conditions on the contract, ie. subject to building inspection or sale of your house?
when's settlement date?
EDIT: Are you able to say what area?
Well after 3 weeks of shopping and 2 false starts, we've found a fully renovated house with huge back yard. We went and put a deposit on a pool for it today :P
Yeah, I've got a condition of the sale subject to building inspection. Settlement is due by 28 August, with a view to moving it closer ... all up to the bank really. Due to my area of work and study, I know a few people to help out in the inspection and additions, including the planned house extension.
Something like this ...
Yeah, congrats Ruby.
Awesome news, hope all goes well.
Im hanging to move into my new house, brought it in Feb, but im renting it back to the old owners, they should be out in October :banana:
We were hoping to keep the current house as an investment property. But decided just to upgrade and move on, rather than dedicate ourselves to two properties. We start paying on the new mortgage, once our current place is sold (or in 6 months, whichever comes first).
will a s2 spoiler fit my car? will it look outta place without the skirts and front bar?
OR
where if anywhere in adelaide can i get one of those drift lip spoilers?
im over the spoilerless look, but i hate the s1 spoiler :P
just had my 32 t boned on wednesday on my bday slammed rite in the side in the centre piller pushd in about 3 inches anyone nows any one wit any left side doors for a 4door n gaurd n centre pilla
Insurance?
Just take a cash settlement and buy a new car (I heard weet-bix give away 32's with every 3 packets purchased now - they are almost that cheap)
If there are good bits on the car you could probably buy the wreck back cheap for the parts - if the parts arent listed in the policy you are entitled to get them back as long as you replace them with stock parts (eg. radio, ecu, turbo etc.)
Time to upgrade to a 34 sedan (under 20k now i believe)
thanks chad :P
its either one of those or a gtr wing ? :banana:
i had one of those drift lips all painted and ready to go on, was so amped to put it on, as soon as i trial fitted it i was like NO WAY. You really need a decent kit like whiplash (back in the day) or SECRET 33 gettin around to actually make it look decent in my eyes. But each to their own. I dont actually mind the series 2 spoiler...stock looking and not outrageous.
hey fishpaste, +1 for Shaun no doubt.
In regards to N1 oil pumps, remember one thing; everything in life has a cause and effect.
If your prepared to take the head off and install a restrictor, maybe modify the sump, consider a catch can, maybe baffles in your rocker cover, and are prepared pay the massive $$ for an N1 pump, do it by all means. You need to decide what the car will be used for and what sort of power are you putting out. I personally feel a new standard oil pump for a street car is fine.
Have you hooked up a decent oil pressure gauge to see what its putting out......low pressure doesn't always point to bad oil pump!
ie. you can run a new standard pump in a tight engine (low km or recon motor) and have higher pressure than a loose engine (worn out motor) running a new N1 pump.
Amazing how many people blame low oil pressure on oil pumps when a crank grind and new brgs would in some cases fix the problem.
The gallery restrictor on the top of the block will even add a couple psi to your oil pressure but keep in mind (from my limited knowledge of RB engines) volume is more important than pressure for normal street use.........at high rpm, most pumps will show reasonable oil pressure anyway.
I had a quick read of the thread that Jess put a link to on the previous page (where the N1 oil pump failed) and from the little I saw in the pics, that guy has issues other than the oil pump.
One day when I do a full rebuild and have the opportunity to do other internal mods, I will definitely consider an N1 oil pump........right now I just can't justify all the $$ for the cost of the pump and labour to install......not to mention that it will throw more oil into your rocker covers if you don't attend to the other mods that I mentioned.
I didn't realize that a new oil pump was part of the 100K service??
Sled has the right idea!! A good balanced crank/engine will do wonders, a good quality oil pressure gauge will help alot and really a N1 oil pump is just a little stronger..but like Sled said there is always a cause for something like a oil pump failing :blink: i.e sitting on the limiter for a long time is a big killer! Loose bolts can also cause damage over a period of time so make sure you check regularly - crank bolt! But then again these are on race cars, dont think it would be a huge problem on street cars!
For most cars new oil pump probably isn't, but for a track raced R32 GTR its recomended that while all the other work is happening to it that you replace the oil pump at 100k service. And to me it's not really much money for a little bit of peice of mind and i do vaguley remember a conversation with shaun about it and he thought it was a good idea.
either way i'll still be dropping by boostworx and chatting with the guys there before setting it in concrete.
Fish,
Can I just say I use my GTR for a track car and I push it really hard, run around 300kw all day long, I only have a standard oil pump and did have the engine out a month ago to check everything and it looks amazing inside! All I have done is put the oil restrictor in, sump baffled it and put a really good catch can system on which will eventually run back to the sump when I go to my next stage of modifying which will be in another month or so!
But can understand you wanting peice of mind and I do think the N1 pumps are good. I think Tomei is better then Jun oil pump aswell and they pump higher volumes.
haha, lol, talk about old school.........I just read my post again and realized I was calling the cam covers "rocker covers" :blink: I need to get into the 21st century!!
I read somewhere that those JUN oil pumps are so aggressive that they can suck a sump dry in about 2 laps.......definitely wouldn't use one of those without the necessary mods first. And on top of the usual mods like restrictors, baffles in sump & cam covers, and decent catch can.....I would probably also consider relieving the oil returns in your head to get the oil draining back quicker.
As far as catch can goes, I'm going to try the atmospheric style first with hidden breather and just monitor how much oil its chucking in their.....probably use the MINES cam cover baffles to help it. If I find its chucking too much oil in there then I'll have to consider restrictors and maybe even oil return from the catch can......only thing I'm worried about with the oil return is that I don't wanna be increasing crankcase pressure unnecessarily.
haha Old Skool is cool! :)
Yep they are agressive your right so need to be set up correctly and wanting big power before you go for that style I reckon..
I use a two catch can system with overfilled oil by a litre and half (still do this even tho I have baffled the sump). I use the just jap enclosed catch can mounted on top of my head and then the breathers going to another catch can that sits near the air filters which goes to atesmophere. Mine did used to spew oil out oil even with the restrictor in when I pushed it hard around the track after about 4 laps. So we went to this system and has been great ever since, dont have any extra pressure from what I know of cause basically it's just circularting. But I dont have any oil problem's when using it for street use only on the track.
Most GTR's that I have come across that push the car hard and only have atemospheric catch cans will fill them up and spew out oil. Can I ask what you mean by hidden breathers? dumping to the ground?
Well after 3 weeks of shopping and 2 false starts, we've found a fully renovated house with huge back yard. We went and put a deposit on a pool for it today :)
i'll be coming around in summer so i can keep cool in your pool :P lol
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
