Kind of a trading post item, but really just putting it out there to drifters.... I bought some rims for the Legnum which I cant use the tyres (too big). SO I have a set of 4x Falken FK451 245/45/17 tyres for sale.
Two are basically brand new (8mm depth of tread), 2 are on the tread bars (but still ok for drift a few laps). I'd be looking for $100 for the lot, so 2 near new, and two ok. These tyres should be available in about a fortnight for anyone who wants them. PM me if you are interested
Cheers
Lee
Ha! By the time summer comes around, you'll be as large as a whale (in a good way :P).
i know LOL, and since i'll be a whale by then i'll need water so i can survive haha
and your pool sounds like a good place to do that :(
i'm really hating this, i'm hungry ALL the time, i'm not use to eating so much :P
i woke up feeling really hungry, i just wanted to sleep lol.
ooooooooo The Pineapple Express is a MUST see, it's friggin hilarious
haha i'm going to see it again when it comes out :(
Cheers
Lee
Consider them sold if they aren't already.
Aight anyone a panel beater and wanna help me finish fixing the 32?
Just thinking about it, theres not much left to do to get it looking reasonable. Considering it's gone
from this:
to this:
I reckon I've done alright for a ghetto mechanic :laughing-smiley-014:
Even better, all it's cost me so far is one $11 tow rope (which I broke ;) 2500kg my arse).
Edited by AndrewJZX100
ok those that are smart i travelled 325km and filled up with 52lt of fuel so i still had 13 lt in the tank what was my lt/100
whats the fuel left in the tank got to do with it ;) you wanna measure fuel consumption you fill it up drive around till near empty then fill it up again. that way the fuel the go's in the second time is the fuel used to do the distance and the k's on ya clock is how many you've done naturally.
how big your tank is and fuel left dont make any difference when you talking consumption, only when your getting into how far can you still go and get off a tank
Edited by Inline 6
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
