Finally! The DNS got cleared and I can actually access sau!! Wooooooo
lol i didnt save ur number from the PM and i was thinking oh ill just go on tomoz and get it,then i get a msg from some random number and i was like who the hell is this and i couldnt get back on to check to see if it was you haha.i concluded it would have to be tho so i finanlly wrote back :O
Oh lol sorry man, I thought I mentioned in the message it was me and not some random hahaha.
How was Autosalon on Sunday?
Hahaha cheers for the extra post jack :O
I didn't actually sign in as me....i put my login details in, clicked login and then it said "blah blah blah SAU is down etc.."
So obviously as soon as it worked again you got signed in as me :ban:
Did you read all my messages? :sick:
Anyone wanna swap rims with me? my cracked rim will be replaced very shortly, keen to swap for some 18's with 18 x9.5 +15 or around that, with cash adjustment if need be. or buy my rims outright for 1400, i got my eyes set on a set at the moment!!
Speak to Ryan at ISC, I know he has some wheels he needs to be moved!! They might be what you want, make him a reasonable offer and they might be yours!!
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
