Ok, installed an air vs fuel ratio meter that i got form jaycar... now its not the most accurate thing out there... but the fact that i built it and wired it in
merits some satisfaction :P Just thought i'd share! :D Oh coincidently the alarm beeps when i need to change gears! WOO
Edit* Looks cool at night too!! with all the little LED's dancing around XD
Joel you need to learn to read thats twice now you've been given an answer today and you still asking the same question
i told you up the said check your afm elec. Cleaner might not be enough Damo there over 20 years old
my car almost got defected :D
luckily i got an awesome cop who has given me a week to get EVERYTHING fixed
he did say if he sees it on the road next week in the same condition he will defect it.
oh and my suspension is too low :P which is weird coz no1's lowered it unless my
brother did it it without me knowing lol
yes, yes i do. went from a job with random hours at a low-ish pay rate to working the last 3 month with consistent hours at a high-ish pay rate this = mega tax refund!!! =)
same! thankyou ATO :P
What do you mean Joel? The plug
you need to unbolt the whole lot and spray the needle on the inside and dont use degreaser
lol damo ner ner...
could be.... i pulled the top AFM off to clean it but it was already sparkling so i didnt bother about the other 1.... maybe its worth looking at...
those chromies on your car damo look crazy when the spokes are painted with 2pac gloss black! a mate of mine did it and they're not bad at all
I was going to say the same thing :P They look pretty good but would look alot better with black spokes
200-300 for the front bar sprayed maybe?
but when i went to arnedale to pick up my mum there was a freaken RBT on the street where the carpark is where bunny had her cruises! cop asked if i had a bov i said yes and it's stock, he let me through :P
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
