thats not too much... i need to get the front bumper resprayed asap so I can add a few finishing touches of my own before fitting it back up :P
this is what I did...
the blue/shiny bits will be hidden behind the bumper - though it looks nice like that with the bumper off the blue and the bling breaks off the black nicely haha
I was considering painting just the piping but photoshopped it thought it looked a bit odd so I did the whole thing heat resistant black, no primer - will black mesh off the middle section and wrap the pipes in something else black I reckon coz not sure how well the paints going to hold up on the sides there - the chrome hardly stayed shiny with rocks and bugs flying at it!
well steve/damo pretty sure you guys were right about the AFMs. im about to pull them off and have a look now. My car cut out 3 times on the way home from work, pretty scary lol
booked into the mechanics tomorrow morning, hopefully they can make heads or tails of it.
Quick question, anyone know if turbotune are open saturdays? Or even boostworx? Even if the car can be dropped off on a saturday and moved around the back or whatever to be worked on/looked at on the monday..
ah joel you dont need to take it somewhere (where are you taking it)
go see Wally @ Z-imports next to Roccla Besser @ ottoway grand junction rd when i was there 1.5 months ago he had 2 gtr AFM's like 60-80$ ea. from memory get them and that should sort your problems
Jarrad - boostworx is sometimes open on saturdays but i dont think he answers the phone not sure about turbotune maybe ring tomorrow and organise your drop off
Thanks guys, and girl. Might give them a call tomorrow, dont know when its going to be dropped off as yet, its being driven the night we go to pick our hoodies up. May be safe booking it in early september. Ill decide tomorrow.
DTM are out of stock in 18 x 9.5 +15 :whistling: gotta wait for their other stock to sell before access get new ones (ie they have to sell the 18x7.5 +45's etc :D ) might look at the Origin DNA01's....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
