I was just thinking, if we have an SAU christmas dinner, we had better start thinking about bookings. Id do it but im doing my work one atm, and that's even doing my head in! Anyone keen?
love you long time damo :(:P
eddy, i reckon if the 32 wins it would go to flick cause the profile was created under her name...maybe lol
Yeah, I don't really care if it wins or not...like I said, I haven't even look at that competition for several months so unless others vote for it I doubt it will win anything.
Yesterday I was having trouble with SAU loading at work for some reason, so I searched it via google to try link in, and to my surprise, look who comes up as one of the main items for a google search..
I think you need to slow down the posting or something steve, you're world famous now! LOL
:P I got that page too!!!Maz you whore it up!!!
I had to delete all my cookies and files on internet and start again..YAY for SAU being back! :(
yeah christmas dinner for sure but it has to be kiddy friendly as most would want to have our kids there maybe if nightcrawler or someone would like to dress up as santa we could have him give out pressys for the kids (that the parents would buy)
:(:P:(:rofl:
lol whats with you and baking nene?last night you were really keen to bake something too lol! i swear if a VL wins that comp for zoo it just proves the bogan comunity is out in force lol,have 20 votes to yours :( .
mmm im siting at my work desk and wendys is right across the hall and the smell from the hod dogs is wafting over here,im so hungryyy!!
how did you manage to electricute your self?
