i hear this, i think everytime an aurion has pulled up next to me they have wanted a race. i think the 200 kilowasps propaganda goes to their heads
yeah 200 lkileelr wasp forht em iddle spec one. TRD = 240 kw :D iyt'd also probablt rip most old nsisaan a new arsehole with a funny hting called toqrue and driveability.
anyway I still olikel nissan my shitbox nissan is okya
Deja vu!
Got pulled over last night at the same spot on Port road for the RBT. Same cop RBT me, another cop shone his light thru my cabin, asked about the GPS (thinking it was some boost controller no doubt) :laugh: Again I got asked to pull over up the road and they looked over the things on the stagea as the night before. :bunny: Didn't say much, just looked at it alot and let me go! :D They gave me a vote of confidence tho, said my "import" was one of the "more stock looking" ones out there.
Sounds like they're keen to nick yas for Apexi gear or boost controllers or even the monster tacho. Watch out guys!
Ruby: 2
Cops: 0
:D they might push for overtime and trip and fall in the penalty box pushing a penalty shoot-out
in other news my daughters under 8 school side won yesterday but i was sick and had to stay home :laugh: ah well allways next fortnight and carnival in 4 weeks :bunny:
EDIT
2eb0_10.JPG<<Click
oh and thanks steve, any idea how these things are installed into a gts-t? Im pretty sure i can work it out, just dont know if its been done and how..
its driver information like speed, rpm, engine information simular to the pfc hand controller but with larger colour screen which also has an AV input for a dvd/tv if you desire.
Edited by Ryanrb25
okay, flame me for tryin (and failing) to use the search properly
tryin to find someone who can make me up custom stickers
nissan want to charge a bomb for some new sticker badges for the patrol, so i want to get some done custom (i dont want them in the dark silver that nissan did them in anyway. one of the only tidy ups i have to do externally, and a badge upgrade will bring it a bit more to my liking
any ideas?
no badges, go full stealth.
lol, it aint a skyline. i want people to know its turbro LOL
i have a friend that cuts vinyl i can ask we need to make Vectors of the art you want
ah k cool stuff. any easy ways to make the vectors of the badges?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
