hey Chad if you're serious we should go and see him together.....might get a better price for a couple of sets.
yeah, im serious. i want some new pipes before the turbos go on, im still pretty keen for those Greddy ones, just depends on the cost difference.
well i just need ones to suit 32, i have 34 front pipes now, so i'll have to modify my exhaust back to 32 specs. which should give me more ground clearance i hope.
Also dropped off my 34 gtr rims today to get painted, think im gonna get them painted the same colour as my Drift Teks.
so, got bored at about midnight, so i decided id take advantage of the half not shit weather and go out and get some pics of my car. found a pretty good spot out in port adelaide, and i stole petes spot in reynella :O, pretty cool for a church, lol.
shame the camera was acting pretty freakin weird for the last couple hours :P
we should probably just rig the lotto.
takes care of that 'work' issue.
that being said, i could go out, get myself a gambling addiction, have myself self-barred from all gaming lounges in sa, then claim work cover cause of my temptation to gamble while im at work :O
... yeah, rigging the lotto is a better idea...
is it the whole kit globes and igniters, becuase HID globes are different to halogen globes :O
Lol Steve of course it is the whole kit. however, i did buy globes to suit an R34 from 666DAN, then realised i didnt have factory HID installed, then i bought a HID kit to suit R34 minus globes.
666DAN
Yeah....666Dan, his kits are tops... make sure u specify if u need the aircon leds in addition to cluster/gauges...
also, i got an entire set of red ones that I took out to put blues in if anyone wants em
-D
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
