who you with, i got my renewal today :banana: my insurance has gone down again and not the agreed value :yes::D now $777/yr +1 for being old
Just Cars - they're the only ones who will insure me for a reasonable price :blink: Rating 3 I'm getting there!
this is the internetz where all psychiatrists :down:
+1.
Woke up this morning with a pain in my sternum. Either I got kicked in the chest by Chuck Norris, last nites bourbon burnt a hole thru my oesophagus, or Im having a 12 hour heart attack. Hurts like watching australian idol when I move my head back or to the right.. gah
-D
i woke up with a massive pain in my stomache, but luckily for me it can be cured
with food :banana: haha
scooba steve,
would auto perfection still give me that deal on tint mate?
um what deal was that
Thanks steve, I sent PT a PM.
Where does he work from?
mt barker and hindmarsh
im thinkin about getting a new stering wheel...
this one tickles my fancy
Isotta Zulag
also this
what do u guise think?
i think you should look on yahoo auctions and get luke to import one for you save you $$$
170x170-2008082600003.jpg<<Click
>>Yahoo Auctions Momo and Boss kit Search<<
