imo, he should be a man from the start and take his responsibility....whether theyre a couple or not, doesnt make a
difference, it is still his child!
i hate pricks like that.
says he with no children or never been in that situation
ha yeah it's amazing how fast some people change when they find out they got some1 pregnant.
i don't know why i bother with him though, trying to get things sorted out so were atleast on
better terms but yeah he's barely interested in doing that.
it's exhausting lol and i barely have any energy
Its a fairly big thing for a bloke to be having a child. It freaks them out quite a bit especially if they are young. He will be up and down.
Maybe start taking another approach.
Take a step back, don't be angry, give him some space/time without harassment once he sees the baby his instinct should take over. Hopefully. :S
I can see where you're coming from Craig and at the end of the day you are right but this guy is obviously pretty young and stupid so logic doesn't always come into play. I'd have to +1 with Cubes advice cause if you back the kid into a corner he'll either do a runner or hang around for the wrong reasons.........then it's FTL in both instances.
Cheers to Andrew and Chad (as well as Jeff?) for the cruise through the hills. Great to go cruising with someone from the hills so you can find all the hidden treasures.
No worries mate, cheers for makin an effort to come up and make a good drive out of it.
You should PM the user 'ABU' about the offset and sizes he had on his GTS-t
I don't know offset but I think it was 18x9.5 and 18x10 with slightly pumped and rolled guards.
Far out Jarrad, how sik does that look?!
It's amazing how good (and tuff) a 32 can look with the right wheels.
Having said that, that tyre's probably screaming at you at every corner and threatening that it's had enough being on this rim. :w00t::nyaanyaa:
Regardless he's not handling it like a man so its time to improvise. Not everything turns out the way it should.
I think he's just completely freaking out. People/kids do strange things in times of stress.
how would you know i have never been ain such situation steve?
NEVER ASSUME!
im simply saying, he should own up to it and be a man,
telling the mother to be, that he hates her, is purely f**k wit!
just because i have no children of my own yet, doesnt mean i cant voice my opinion.
NEVER ASSUME!
so HAVE you
otherwise my post still stand if you have i stand corrected twice in 2 days
haha fat as hey. I think hes gotta R33GTR now with some crazy offsets, he's pretty mad. Only in Victoria though haha
I could imagine that cruising down The Bay and getting raped by cops ;)
I've got a story that happened to a couple mates when we were 18.
2 mates.. One going out with this girl. We all went around to her place as her mum was having some party/gathering.. In short the other mate hooked up with the 40yo mum and she fell pregnant. His parents were asking to meet the mum of their grandchild.. Quite funny times.
Later another mate hooked up with the mums friend purely for 'experience/learning' reasons. But bugger that they were cops to put it politely. Don't know how they did it.
All occurred down south. I guess thats enough said. lol
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
