got a pic n how much dude?
like this one here mate, ill sell it for $20
http://cgi.ebay.com/ebaymotors/Nismo-Leath...sspagenameZWD2V
ive still got the stock knob out of my 180, i kept it when i got rid of the 180. i love the feel of it, and have never felt one that feels as good.
too much info ted :O
Edited by Sambo33
hey man link doesnt work says item has ended or been removed
you need to re-install all your programs flick =(
you can copy files, but not the programs... despite what ted says
i disagree whilst some programs WILL need a proper installation a lot wont and if you want to take it to a smarty pants on the forum you can copy registry keys and load the keys up after dragging and dropping the only problem you will/may face is if the said program installs .dll's into windows directory but you would usually get a error about what file is missing :)
lol steve...
who thinks 13 is fair?
with all the goodies of course
sounds ok man got a few goodies :D gl with sale
300++ here you come.
Have you got internals done or you looking to find what the stockies can take first?
lol nah, gonna run max 1.1bar through stocky motor until i get it built hopefully once funds permit. Should still be lookin at around 260-270rwkw...Im actually looking forwards to less response more traction.
So i may need some help with this then. Re-installed my photoshop, but dont have my original serial number. Would like to copy it over to the new computer, as it has a few batches/scripts set up, that i dont know how to redo, as someone done them for me. Was hoping to copy the programme straight over so i could keep these scripts.. if that makes any sense
i take it the computer there coming from is a desktop ie unmovable easily
Both laptops.. Ill bring them both to Lukes saturday night (if i havent sorted it out by then). Few people that are going including u, might be able to help me with it
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
