dont have dump pipes yet or boost controller plus i want braided lines which all = dollars
Chad, you don't need braided, they're cop magnets, stay black.
And I already told you that I'd do you a deal with my split dumps and pay me whenever.
So all you need is a boost controller.
You've got them now so get them on there the same time as me.
Cool thanks Pete, i just want braided lines cos i plan to be hitting the track a fair bit, was going to paint them black so they didn't stand out. Just need to work out what boost controller to get, i prefer one that i can hide in the car easy.
i dont think work misters are 2 piece?
i can see studs between spokes :banana:
Theres Miesters SP1 and SP2 ? One is 2 other is 3 piece rim ?
Then there is also the SSR Proffesors (i think) which are pretty much the same rim...
Correct me if im wrong.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
