last i heard she was in intensive care cause she couldn't breathe right and her heart rate had significantly increased
that's all ive heard , going to go over to her mums place this afternoon probably seeing as i was the first person she called cause we hang out
every weekend and she knows about me etc etc
respiratory problems would indicate more than just alcohol poisoning you would think...........be interesting to see what the lab results bring tomorrow
yeah sorry to hear mate,know exactly how u feel,i cant seem to go anymore than a few mths without bad news,my brother is still in hospital after his bike accident two weeks ago,just got to try and stay positive and hope life gets better :(
Heard about that Damo. Didn't feel it was my place to bring up that topic with ya ... but wishing him the best anyway mate. :ermm:
PM me if ya want.
BTW Cam's birthday is coming up soon and the girl is invited (and you guys of course). Looking at doing an Aquatic Centre birthday thingy if our pool is not up and ready in time.
anyone watching the story on ethenol on 60 minutes?
60mins FTL.
Its good stuff and has been used oversea's for quite some time without issues.
What was it they are claiming? :ermm:
The basics are
Old fuel pumps = they break
Old fuel hose = they break
Skylines.. Replace the fuel pump and rubber hoses and up to >40rwkw (if not more when you push in more boost etc) at the disposal of your right foot:)
Fuel economy can take a hit if not tuned correctly.
PM me if ya want.
My girlfriend and I will be around! :(
Came home last night from my sister's to find my dog on the street corner. Found out how it got out ...
Some trespasser(s) tried to get into my property. Rollershutters all around and good security, so they tried the backyard. Forced the side gate open and discovered our black staffie. They musta shat themselves, because thats as far as they got before running. Obviously my dog gave chase and we found her around the corner from the house, so we just missed them by mere minutes :(
Went and got a few extra items today :)
"Beefing up the home security" :ermm:
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
