I find 7000km is pretty much it for mine.
It tends to develop a little lifter tick first thing if the oil isn't changed at 5k.
I run plain old 8100 5w40. Motors now done 90,000km's still top compression, bores still look tops and no deposits in the top end.
Same here.
I run with Motul 8100 and get it changed every 5,000kms.
Hammer and screwdriver always works well :P
J/K I got a good filter removing tool thats never let me down :banana:
lol i must off done the hammer and screwdriver trick way too many times, works every time tho :P
i must change my oils etc over soon
is motul 8100 ok for rb25det i was tossing up between that and motul turbolight i think its 4100
I was told that if your changing the oil every 5,000kms then 8100 is fine. If the change is only every 10,000kms then 4100 is better, but its double the price.
Do the maths, same price in the end for the 10,000kms change(s), but fresher oil more often is better (every 5,000kms). :P
Hammer and screwdriver always works well :)
Not always. I had a dodgy filter on my old 180, tried the old hammer and screwdriver trick, managed to rip through the oil filter and rip it in half. After lots (lots) of cursing I got it off in the end :P
Edited by AndrewJZX100
Cheers mate
Be careful if you park your cars in the Ascott Park/ Parkholme area. I left my car parked on the street outside of grandmas while i fixed her car yesterday afternoon only to find some fk had loosened some of my wheel nuts. I very much doubt whomever did it was trying to steal my wheels as I'm only rolling on stockies atm.
me and the m issus just went for a walk to the local shops,
on the way, a red/maroon ED falcon come speeding eound the corner, massive understeer, nearly collecting my girlfriend on the foot path.
i let him have it with a few words that start with F and C...
as he was takin off, he slammed on his brakes leavin a good 15 mtr skid mark, stuck his head outta the window and yells
out ''You got a fckn problem?''
as soon as i started walking toword this skum bag prick, he floored it and took off,
lucky my missus got his rego, and i reported him to the cops.
is this what the world is coming to? cant even walk to the local shop without f**k wanks like this
getting in your way?
i tell ya what, with the adrenalin i had after he nearly ran over my girlfriend, he is lucky he took
off, call me a key board warrior if you must, but i know you would do the same.
:P
:P
GRRRRRRRRRRRR theres so many wankers in Adelaide. :)
:P
rofl i love that, those pricks that slamm on there brakes thinking your gonna back down, or the wankers who tel you to pull over during some road rage, acting like there gonna get there box on then as soon as they realise your actually pulling over leg it.
i had one prick start showing me his tats like it was intimidating or sumthin???
ouch the crash of the dollar has to hurt is it worth selling up the rest of them before just in case and if it doesnt crash re buy them back before they go up again
i was considering selling, but ive had the portfolio since before i knew what the market was, it seems like a lot to sell.
even Wall Street in 1984 recovered...........unless you'll be retiring in a couple of years, leave it alone
haha, it is basically my retirement fund.
thats another reason im reluctant to sell, hit a pretty epic slump on friday, but im quietly confident it'll crawl back up. made back a few thousand today, so im pretty happy.
:P
Just sit tight. It will recover. Those who will sufer will be those shifting their interests around.
Its the fools who panic and move things around who make the ripples in our economy worse.
yeah, i dunno wanna go f**k myself even more by moving my shit around, its worked pretty good for me so far, so i know i shouldnt change it, but shit, when you see that much disappear, you dont think so well. :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
