Hey does anyone know where to buy one of those R4 DS Lite Chips thingo? lol the one how u can download games on the memory card and just play??
They no longer make the R4 cards (I have 2 and they are great) but there is a replacement. Go to http://www.ozmodchips.com they have great gear and are reputable and well priced.
yay for 1st home owners grant increase :D
Pfft, I got mine when the $14K was standard the first time >_<
I'm on my third house now, so I cant get it ... unless I use another name :)
wat can u build a 3bedroom house for?
Thats a bit of a broad question with not a straight answer. Depends on the land price and selection of home to build on it.
These $200K packages will only get you shit locations and homes nowdays.
I built my 3 bedroom home 6 years ago in the Sheidow Park area on a 14m x 34m block for a total of $142,500 ... only 6 years ago! Sold it last year for $345K. The land alone cost me $45K then. Same size land is $180K-$200K now ... madness! To build now what I built then is over $300K. There is no way I would build now. Greedy builders and greedy government. Money is better off in already established.
I shopped around for about 6 months before I purchased my new home for $340K and its twice the size of my property sold last year. Plus I'm adding on an extension for 2 more bedrooms and a bathroom starting in the next few weeks ... oh, and still plenty of room for the 7.3m long pool and my 2 car garage/workshop. Designing and building it myself. >_<
I shopped around for about 6 months before I purchased my new home for $340K and its twice the size of my property sold last year. Plus I'm adding on an extension for 2 more bedrooms and a bathroom starting in the next few weeks ... oh, and still plenty of room for the 7.3m long pool and my 2 car garage/workshop. Designing and building it myself. :D
you'll have to let me know when it's done so i can move into my new room >_< haha
Im pretty sure that when you go through regency, they will make you peel any non-standard tint off the front side windows.
black glass on R34's ftw :O
Black privacy glass on the Stagea ftmfw :(
Couple of us are going bowling at Bowland Salisbury tonight at 8:30 if anyone wants to come? We have 2 lanes booked so you will have to book your own. 2 Clayson Road, Salisbury East.
i thought that tonight the meet was at villies
what happened to that????
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
