ummmm ruby has the first bike in the pic very fast and a comfortable ride for passengers i love being on his bike. ask roo about it if you want one :thumbsup:
ahh i was just saying i'd spend a bit more and get the newer 1078cc model...
Bah i like the new model with the 1078cc engine.
Yeah, certainly a nice piece of kit *drool* Looked at one of the 1078 models also today, as well as the 312. But I have a double mortgage now, so if I did get an F4 it would have to be the 1000S. Maybe stretch for a 312.
A Senna would be nice but I like to take passengers. Ultimately, an F4 Tamborini would be the ultimate ... but thats $74K I do not have :thumbsup:
holy shit, just working on my garage thing in here. Rough total spent on my car so far just above $15000 :)
lol, my car owes me at least double that :thumbsup:
lol i recon we should ask GRIM how much he has spent on his cars Grim and rs260 lol that would be interesting
you have good taste, but i personally think the F4 is getting a bit long in the tooth. It certainly is a beautiful bike and one of the best Tamburini has designed but the rear needs some work, it's a tad to fat for my liking, and the headlight area needs attention. Hopefully with some cash from harley davidson they can launch the next all new model.
Also i personally find it hard to justify the extra cost for the MV over say my bike. Yes i know mine isn't as coverted or "unique" but for the money nothin beats a japanese inline 4 sports bike!
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
