my mate just called me saying how he just got DEFECTED......
the f**ked up thing is he gets a $200 fine to go with it....
now to get defected (have no car), pay the $140 inspection fee, and $200 fine is totally f**ked up...
it makes going through regency well ober $1000
im pissed hahaha..
/end rant!
Went up the hills yesterday with the needle a little under the lower quarter mark, getting towards hahndorf petrol was on the empty mark, didnt see a BP so headed back the adelaide hahndorf road driving "spiritedly" and by the time I got to a BP back at civilization fuel light flashed 4 times on the way- turns out I had 9L of fuel left(thats if 33 tanks are 60L?) and got 478km out of that tank including that "spiritedly" driving lol love the fuel economy!
im pissed hahaha..
/end rant!
What he get done for?
anyone know where i could get a battery for my car tonight ?
my car is dead and i have to keep using the portable jumpstart battery pack thing to start my car everytime :P
u can get batteries at some 24 hour servos
cant think of any offhand tho
-D
im pissed hahaha..
/end rant!
that's always been the case just lot of officers don't fine us when defecting
R33 tank is 65Lt its my understanding that once the fuel light comes on there is 15lt left in the bottom of the tank it may be 8lt i cant remember, i know i read it in my manual though
-D
BP on north east rd modbury has batteries but i doubt they would be the small variety that is in the boot of a R33 you could get your part number and ring them
i might just wait till tomorrow , fair hungover and really cant be buggered driving anywhere haha
hahahahhahaa..... dude u should c the parties they have!
massive chick fest.... gotta push the 32 out and make out im working on it.. try pull them in...
"oh u have a skyline" hahahahah
Now ... if you had a Stagea, you could invite them to see the back :laugh:
:P
hey mate,
go see Edwardstown Custom Body Repairs, speak to Mel tell him Craig's brother Luke sent u there.
Its on Bennet ave cnr of Iris st melrose park, near daws rd.
They will do an awesome job.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
