Probs because Aurions are advertised as some sort of speed machine!! haha
For 3 set sof lights I ignored the bald f**ker, but he continued to want to drag me off and cut into my lane when in front ... even tho I was driving normally :)
Gave him the "wanker" hand signal for his worries :O
Also ... had a truck (earthmover/tipper type) sitting up my arse on my way to TAFE this morning. He was hustling his way thru traffic, but got caught in the wrong lane (by car turning right). He pulled into my lane without indicating, cutting me off, then moved slowly (gutless rig) around the turning car. As soon as we were clear, I changed to the RH lane to go around him, and he cut me off again without indicating. So I sound my horn, get back to the left lane, around and into the RH lane I go around him, all with safe distances. He highbeams me and gives the bird, even tho I'm like 75m in front now. I had to stop at a set of lights 400m later, so he stops right up my arse and sounds his horn. When traffic finally moves, its at a crawl (40kph) so he's right up my arse. I slow down enough to create a gap with the car in front and speed up to create a gap with f**khead truck driver. Next set of lights, he pulls up almost next to me (just in line with my back wheel) and starts hurling abuse. I casually hop out, write down his rego plate, blow him a kiss and get back into the car. When the traffic is moving again, he's trying to hustle his way back into my lane, but by the time he did (cutting someone else off) I'd already turned off South Road. :D
What a f**king nutter!
Edited by RubyRS4
i have skipped brekkie today cos im going to hogs breath for lunch with my gf
im going to inhale a garlic mushroom prime rib
yeah yeah yeah..........feel free to post up a pic of the balfours pasty or cheese & vegemite sangers that you're actually having.
did you cook yours pete?
absolutely
ok carl you cook for me one week and ill cook for you the next week and we will tie pete up both weeks and eat infront of him lol
i also use the finer details of olive oil as well cant cook with anything less
only if you slap me in between mouthfulls
OK, a very simple lunch today consisting of pasta with fresh mushroom, mussells from Cowell and some red salmon pieces in a white sauce topped of with shaved parmesan.
Get your act together Carl or you'll fall behind.
.... OK, a very simple lunch today consisting of pasta with fresh mushroom, mussells from Cowell and some red salmon pieces in a white sauce topped of with shaved parmesan.
zomg Pete, did you really cook that yourself? If so, your vagina is showing :bomb_ie:
so wednesdays are the boys dine out night and beers and a cruise, we have hit, highway in, jetty bar, the dublin, the pier, ramsgate, seacliff hotel,haundorf inn, that golf range pub, and cant remember else! stuck for ideas on where to go to tonight,?? any ideas?? has to be decent as i am a qualified chef, and a picky kent at times
Coopers Alehouse FTW. Griffens head is nice but unsure about the food. Mawson Lakes hotel makes a mean schnitzel, Strathmore hotel (across from casino) if you like cooking your own steak on a hot piece of stone.
yea heard good things about the ale house but heard it was more snitzel based and i like to try something different when im going out for dinner! i like the relaxed front bar scene with top quality meal and my fav beer haun superdry! use to be a ted boy through and through like wouldnt drink anything else, but haun is better and low carb!mmmmm i write this as i drink one now
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
