yeah i seen that photo album function... i was reading somewhere that you can save the snaps to your usb memory stick or something. cool feature.
hey do you guys know if you can buy R33 and 34 GTS25T's/GT-T's in Gran Turismo 4? i've only seen the R32 GTS25 and GTST in the used car sections
well its 118 for accomodation, bout 600 for petrol total, so 200 for you (600 divided by 3 people), then dinners and cruises, casino, luna park, i think we worked it out to approx $1500
zomg Pete, did you really cook that yourself? If so, your vagina is showing :banana:
I thought I'd better redeem myself with something a little more manly, that also required beer as a side dish, after Andrew's hurtful comments :)
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
