Madaz....
I translated the auction and it seems it might be for the guards only :)
I'll do some more snooping and confirm :D
Very nice Andrew all i want is the guards cheers for helping btw i have GTR guards already and a GTR front bar
rofl carl
that car would be porn if you replaced those gay rear lights and took off the gt wing.
http://www.skylinesaustralia.com/forums/to...20-posters.html
SA Dominating as usual
Edited by Damo_R34
i thought i was on ns.co for a second looking through some threads....
seriously ppl need to keep there personal shit off the forums..
and stop making trouble!!
ffs how are we ever gonna get a sau SA car club!
/end rant.
mitch, good luck with selling the car dude, i might have to buy another ride and see if you can keep up with me in the new one. :D
/end rant.
yeah, im starting to get more than a little tired of it myself. couple months ago it was pretty f**kin awesome around here, now everyone is going crazy with sharing their beefs with everyone. for f**k sake, theres better ways to deal with shit like this, pm, phones, a boxing ring, a kiddie pool full of jelly, take your damn pick, just sort it out OUTSIDE of the forums. personal issues in your own time. enjoy the forums, the meets and the cruises for what they are, an opportunity to catch up with mates, talk some shit about cars, and have a thrash. if youre not fond of someone else at the meet, avoid them! pretty f**king simple really.
/rant.
Agree'd, WTF were they thinking with those tail light covers :D
I also found a few other things like weather shields and some interesting front bars/bodykits for 33 doors while messing around on there, thanks to the shit exchange rate they weren't cheap though :)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
