my car started misfiring under high load the other day (ie ~5500 whilst wheelspinning in 2nd) so I took one of the spark plugs out (CBF doing the rest :) ) and it looks like this:
Is the whiteness something to be worried about?
Anyone?
Gap looks standard 1.1mm ?? should be 7-8mm i think mine are even 6mm i was planing on running large boost
as for whiteness i don't think its anything to worry about i think its heat affected metal ??
i found this 1,627,500.00 JPY (Japan Yen) = 26,404.34 AUD (Australia Dollars)
>>source>>
RB30 OS-E2996
Developed for those special customers who feel that 2.6 liters is just not enough.
OS Giken RB30kit contents
RB30 OS-E2996
- 1 cyclinder block
- 1 billet crankshaft
- 6 billet-forged connecting rods
- 7 crankshaft main bearings
- 6 connecting rod bearings
- 6 forged aluminum pistons
- 1.3mm metal gasket (1.2mm, 1.4mm and 1.5mm
gaskets available)
- 1 timiing belt
- 1 belt tensioner kit
- 14 custom made reinforced crank cap stud bolts and
nuts
- 3 M6 bolts
Now that I can believe.........$AU26,000 for an OS short motor that includes a full counterweight & big stroke crank with sleeves, deck plate and all the you-beaut internals.
I just can't see why someone would pay $30K for a block alone that can still pound a brg, crack a land, throw a rod, etc, etc!!
Yeah I noticed the gap was kinda big for our cars. Anyone up for a drive to the hills to help me change em for a 6pack o beers? :)
Feel free to bring the car down to Campbelltown though. i just got home from work and will be up for a bit. lol
what are your thoughts on this looks responsive enough and a little more balls than the 2871r just suggestion.
~GT2876r click me~
The GT2876R is a poor mismatch between the turbine and compressor. The 76mm compressor wheel is too big to be driven by the T28 ns111 turbine wheel.
This is highlighted on the Garrett website where they say;
* Not recommended for general performance applications
* Best suited for unique applications such as asymmetric turbo installations
Edited by D_Stirls
Hey mate,
I work in irrigation facing Currie street. I wouldn't be surprised if you didn't even know we existed, no one does!! lol. It has been decided that we have the better spot as we have windows facing the main road.. Let's just say, during uni and summer, awesome views!! lol
Anyway, the wheels...... What are you after for them? I have a mate that is a BBS fan boy who might be interested if I give it a miss. Can post pics if possible?
Cheers,
Peter.
Thought I'd move this post to Wasteland so Andrew, Joel or Matt don't smack us, lol.
Here's what they are.........haven't thought about price at this stage........265 x 35 x 18
Gap looks standard 1.1mm ?? should be 0.7-0.8mm i think mine are even 0.6mm i was planing on running large boost
FIXED
i wouldn't go any lower than 0.7mm, No need to and it effects your idle. Will bounce and pop at idle if any smaller.
It's amazing that the block costs that alone AND that Keir has blown 5! What is the exact difference in the OS block that makes it so awesome?
It is an engineering piece of art .... and people make serious power with them, that they just cannot make with a normal block
Nice find Steve - you do realise of course that it would cost you $10k+ to get it here including shipping, taxes and GST?!
Seems the price has come down somewhat .... mind you, it doesn't look like that is coming directly from OS Giken (with all of their associated knowledge and warranty that comes with it), so I guess it is from a cheaper distributor or something. Also sounds a bit fishy, since it says in 1 place 3lt (2996), but in other places it says 3.15lt. I guess that is a head gasket and piston stroke issue maybe.
Had a tinker around with the GTR last night and found that it still has the stock boost restrictor in one of the vacuum lines (Nissan put it in to meet the gentlemen's agreement and circled the line with a yellow stripe, etc etc etc).
Can't believe that none of the previous owners in Japan took it out to get a safe boost increase! Crazy.
parking in a loading zone that turns into a taxi zone at 6pm = fail, $79 fail
ahwell, my fault lol
parking on a main road at 11am that turns into a bike lane at 3pm. then get stuck doing shit when you thought you were only gonna be there a couple of hours and leave at 4:30pm = $148 fail!! :yucky:
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
