I like the carbon air box Mark, is it a custom job or did you buy it from somewhere.
I must get something similar b4 the hot weather really sets in.......no point having pods with a HAI, I reckon the stock panel filter with a CAI setup would be better in the middle of summer.
Just a quickie
RB25 and RB20 turbo share the same sort of inlet yes? ie if I was to get an alloy intake pipe for an RB20 turbo, would it fit the 25 one no dramas?
Wanna get the shitbox fluttering its tits off for some cheap laughs :)
Time for a bash through the hills then. ;)
ya know im always down for a hillzy with a dale but the bald tires and shot suspension have me sketching... once its all done u'll be the first a call for a decent cruise.. always happy to whatch the big blue flames come out the back of ya beast!
hey pete! the carbon box is a just jap item i bought through the forums... saddest thing is i had to cut alot away for my old plumbing setup now i have heaps of gaps... you have to seal all the underside of the pipes reguardless, to creat the full box that protect from hot air. still in the middle of making bottom section up.
al in all i think the modded stock panel+box is the go. i was looking for one before i got the piping... now i cant do it but if the mines 34 has stock airbox u should too :)
On that note, has anyone had any success with these, it drives me nuts trying to set it up.
HKS EVC 5
They have all the basic sorta principle, all have the same features you need to change, only thing is yours is a bit fancier than the rest and may have some other safety features.
Got quoted about around $780 for the 100,000km service on the stag, but not including a new water pump. Apparently it doesnt need to be done until it starts leaking?! Reckon this is fair or who knows where we can get it done cheaper??
Sez
Sez
who was that with
i paid $600 for boostworx to do mine and a stag is just a big skyline :)
other people will recommend other forum members to look @ but essentially the choice is yours
Just a quickie
Inlet yes. They are the same.
Thanks scandyflick
Sez
Hey Ryan&sez, By all means choose who you feel comfortable working on your car, however, if your not happy with the price you have to pay for a 3 hour job on your car then i'll do it I've done about 10 or so for forum members and try to keep it fair for both you and I. I use all Genuine parts (your choice obviously) I've seen some water pump's leak at 40,000km and some water pumps that will never leak so it's not a good indication of when to change it. Because if your going to change the water pump you might as well do your timing belt aswell.
Oil (your choice)
Oil Filter (genuine)
Timing Belt (genuine)
Water Pump (genuine pumps are expensive and generic one's are pretty good at half the price)
Coolant (genuine)
Tentioner and pulley (usually dont show any wear at all and are fair expensive to change every 100 thou)
Drive belts ( powersteer, air con, alternator)
PM me for more info on prices etc.
well we just witnessed ben blow the rest of his cat out tonight... a few gunshots and flames...
lol, it was sort of like a fireworks display coming out the back of the wagon :)
haha , that scared the shit out of me , big cloud of black smoke then bang bang bang ;)
MY first words... "you killed it!!" haha
they were some pretty big flames... hehe
it lit up the freeway pretty good!
if only i had my trusty camera man in the passengers seat to take a photo !
it was something you see in jdm option or jdm insider haha
Thanks scandyflick
Oil (your choice)
Coolant (genuine)
hey ryan...
so wat water pump shall i get? and wat pulley should i ask for?
and i got something to give u at the cruise!
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
