I got a good mate of mine that could help you out Pete, i'll give him a call tomorrow.
yes please Chad :P
Pete, told you I can get you gyprock if you like at a nice cheap price. If you're interested, SMS me and I'll get in touch with my mate :)
thanks Luke, I did remember you.
I may be able to get the material cheap through a builder mate of mine (possibly uses CSR) but I just need a hand to do the work.....happy to pay.
Speakin of jobs, I love mine! Average around $800-$1000 weekly, freebies.. bonuses, commision, and relaxed as place to work!
Oh and guy, we have a plumber we recommend, can sms you his number tommorow if u want? Best mates with one of the workers, so does a good job if you saw we sent you!
otherwise you get a subpar job and you have to keep calling him out :);)
i also have a dyno printout thats shows i have 274rwkw and one that says 229rwkw, with no changes to the car at all just different dyno's, but my PFC says they are at 100%, so i have no idea what power reading to believe. Cant wait till saturday so i can see what the boostworks dyno says :P
yeah will be good to run against more of your peers, i was always dubious of your claimed power reading when me and Jenkies drove next to you before he had all that work done
yeah will be interesting.. What boost are u running again?
Usually it takes a good 15psi to crack 240rwkw on stock turbo's on Boostworks dyno.
260rwkw @ 15psi with cams.
Shauns dyno used to read around 10-15rwkw lower than mainlines depending on who straps it down. I'll be there on Sat but unfortunately not running. Too busy with work and cant get down to MTQ to pick up bits to fix the car. :(
ah spewn still dont get to see the sleeper on the dyno :D
***keeps typing fingers away from the$100 formal drive thingy, that thread is gonna get nasty lol***
i lol'd
Guy, what do you need done? I know a plumber (name is Adolf, lol) and he may be able to help. Did the plumbing on my bosses house down in Normanville if you are interested
I am building my house at Inglewood, but its been held up by 2 yrs thanks to council. The budget is very stretched (thanks to an additional yrs mortgage repayments and ever increasing prices) so I am looking for some traidies that will do cash jobs (with me doing much of the grunt work if possible). I have the underfloor plumbing done but will need to do hot and cold water plumbing next (lay 20mm Rehau hot and cold pipe, fit all noggins etc)
I have nearly got my builders licence (Site Supervisor and Contractors licence) and have had experience as a labourer for many trades, so I am attempting as much as possible myself and leaving the jobs I know I cant do to the professionals.
Can also pay in meals and booze LOL
Edited by 4door_Sleeper
lol, I've seen this come up a couple of times now whilst trolling through the main For Sale thread.
Whatever you do, never ever buy any kind of block that has been bored unless it comes with the pistons that it was bored to suit.
So many blocks for sale that have been "freshly bored" but don't come with pistons..........pistons can vary by up to .005" or more between manufacturers and even more between cast & forgies.
If you buy a block that's been bored for cast pistons and you use forged pistons (unless the forgies have clearance already built into them) you're asking for nightmares.
Forgies require more clearance than cast pistons due to heat growth.
Not only that.........you don't know who did the final hone, what stone or paper they used, and what degree cross hatch was used.
Buy pistons first, give them to the guy on the boring barr and bore to suit them with a torque plate!!
right on!
more people getting packages....and just got an email from someone from GMH saying in the first 1/4 of next year their shutting down for 22 working days!! YIKES!!!!
Penny its probably split and i'd guess that its a press in/press out job?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
