in response to $100 dolla bill thread which is better :D numbers dont lie bitches. taken from my orginal gtr special hpi mag. that decimal of a second means im like 1cm in front n stuff.
clearly my penis extension r32 is bigger and therefore better at compensating my lack of manhood than your 33s n 34s
Edited by Inline 6
i could also be agrued that they are progressively faster around a race track through the gen's as ive seen vids of the 33 and 34 smoking a 32 gtr around the race track. i believe alot of that is down to the attessa reprogramming making the newer more 4wd in the corners havin a lil more torque from the motor.
i got love for all of em but 32 will always be my fav, 34 is the best around a race track and 33 is the best value for money i think we can agree on.
and craig i dont diss peoples cars :) because after you drive a $300 dato for 7years its usually me on the recieving end of car disses. gives all a laugh though :P
if they made em smaller id want that 1 too :D 2 seater only 240z style would be crazy
Edited by Inline 6
aerodynamics, improved suspension design, improved chassis design, etc, would all play a fairly important part also. 32 had very little in the way of aerodynamic aids, 34 however...
lol Dan, I can show you figures that have the 34 GTR doing the 1/4 in 12's and 0-100kph in 4.5sec (stock standard)
they say vspec 2 32 can break into 12s aswell, they all just the reg gtr times hpi pulled.
alternatively sled you can pull your gtr out and line me up, its on mofo :banana:
*eye of the tiger beats playing in head
tempretures n tyres n such could play a factor in it when its that close, its a bees dick diff in there times. and i think a ztune should easily pull that sled :P
also note sled im an accountant(numbers obsessed) and i used to read every single magazine that spat out 1/4 mile times for skylines and como's (jus scouting the enemy boys) thats around about what they usually put them at.
^^ i thought u thought (get smart voice) i was dissing peoples cars, never mind all good dude my care factor is very low.
Edited by Inline 6
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
