i vote do it, if you got the nasty holes on the boot from the missing wing could be a good way to cover them while making it supafly
looks like the vspec wing after a closer look no it aint no vspec wing but a simmilar nice style
Edited by Inline 6
dont you mean.......Never oily, Never dry......?!
adrian, nothing wrong with plasmas ive been told, its all about what YOU need it for...
movies and sports =plasma :banana:
Edited by craig R33
i say go the cinema screen,my setup is awesome,i play games watch dvds and due to my tuner watch full hd through projector onto my screen and cause of my surround sound its always cool to watch anything
Well finally got the internet set up at home again :banana: Upgraded a few things with the PC too.
Now I'm setting up the security PC. I'll be able to log on and view the video surveillance cameras I have at home from work or any web connection. :P
Think I've taken home security a little too far? :)
lol adrian, i didnt want to soend 2600 + on a sony bravia, which would have been the only lcd i would have bought
picture quality is amazing!!!
but i cant complain, 1200 bucks for a 42'' plasma = :banana:
hehe... lol its harder for me as im with them all the time and i can pick the difference.. lol plus im fussy but yes GOOd buy!
like i said my grannies is going strong and shes happy lol
Lol Dan, you're a funny boy
Hey Pete, talked to my mate today about your shed, he can do it but he's booked out till Jan.
Thanks Chad, I was thinking to do it in the New Year anyway so I'd be keen to hook up with him at some stage.
While I got you here, I spoke to Andrew (Blue 32) through PM's about going around to his place one day and checking out what he has now done to his car while sucking down a couple of beers and talking rubbish. I told him I might drag you along since you've got a 32 & done a track day with him but I think he's coming to the Dyno Day at Boostworks this Sat so we'll catch up then.
By the way, IMHO, no additions to your bodywork, but that's just me.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
