Well just got back from a quick test run...
Took me a couple hours to fit the climate control's hot/cold door actuator and the rest of the interior I had to take out to get to it... mate of my soldered the dry joints last night...
and IT WORKS! Holy smeg! I haven't had a working climate control since I bought the car and I >finally< have airconditioning at my whim!
RAWR!!!
feel the power! revel in its awesomeness!
Thanks to madaz for showing me the tutorial link, I probably would have missed it otherwise. I owes you a brewski mon!
*sings a song about summer and climate controls while dancing a jig and drinking a beer*
-D
hey guys,
got my car today.. and it dies whenever i clutch in when it warms up..
its got apexi turbo, stock ecu, stock afm, bov blocked off, 3inch turbo back.
any ideas on wat would be causing it?
^ could start with like a process of elimination of things Adrian.
first thing that springs to my mind is get someone to make it stall the way it usually does while you watch from outside. If there's any black smoke coming from the exhaust it's simply too rich at idle/off throttle. If not, you've eliminated overfuelling to be the cause at least :D
Mine did the same Adrian when I used to clutch down to change into 2nd. Sif you never msg'd me to meet up somewhere so I can see the car.
sorry man i JUST finished work! catch up tomorrow night?
Hey was thinking bout going into town friday night or sat night as well!! Gouger street you say eh, might see if wifey's keen n head in!
im interested if others are, last time i went they had those cut out new lancers with forza 2 hooked up to the steering wheel n pedals n stuff schooled all the people around :D for free i might add.
plus ill be done with uni for the year and in need of alcohol :P
RAWR!!!
-D
thats awsome! im yet to own a car with air con :P
i'll let you fix mine up too :D
hey guys,
try unblocking your bov and run the standard one and see how you go?
Well, while we're being stupid, I'll run a pipe off the back of the turbo into the cabin, then I'll be too deaf to hear them complain :D
and be killed by the noxious fumes.
... win win really. :P
... win win really. :wub:
Yeah well I get that already when I only open the front windows, sucks in a lovely aroma of unburnt fuel (see my profile :laugh:)
But yeah I reckon thats a goer, I'll get on it tomorrow :D:P
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
