32's are 360mm front and back!
:wub:
From the regency thread:
Speak to Vehicle standards they too will tell you it has changed.
For example the R32 GTST used to be 360mm all round.
Now its 345mm front 355mm rear.
This is also the same as what the latest vehicle standards pdf document says, as posted by Howie.
So yeah, I'm rocking legal height :D
Combined with the new tyres all round (on stockies) and a quiet as exhaust, I really like driving my car not having to worry about defects :D Lets me contentrate on actually obeying the road rules/speed limits, rather than wondering if my car will be off the road as a result of this drive :O
Edit: This is the extract from the info bulletin 3.
Also, the car has to be re-registered as a 2 seater.
well that sucks, it didnt quote what i wanted
basically in addition, the bit about the seatbelts / seats having to be removed, they forget to mention that you cant just put the bolts back in the seat belt mounting holes. they have to be welded up so that you cant use them again. seems stupid IMO
anyone keen to head out and drink??
I've spent the day clearing the site for the pool, tearing down an old chicken coop, and assembling the wall frames for my pool.
I'm hot, tired and brown from the sun. Time for booze :wub: I've got a mate's house warming to go to tonite. All the biker boys will be there, drinking, insulting and bullshitting the night away :O
hahaha, breatho comps at cas ftmfw!
atleast you get good entertainment for the $1 you put in, unlike pokies mang.
ahhh just poured a glass of primer, wild the sphincter of the universe rare breed on the rocks, mmmmmmmmmmm
think afta workin for a heap of yesterday and not gettin out to pimp round (well, a half lap of town on my way home from dingo woop-woop with the trailer on board) i think im goin to cut some laps. should be tons of hot bitches in town tonite :O
If thats Wild the sphincter of the universe 101 proof, I'm coming over :O
Edited by RubyRS4
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
