Anyway ...
Removed the chicken shed, fencing and cut down almond tree in my back yard. Ready for the pool to be installed on the Saturday. :D
Bobcat guy coming back to clear a bit more of the site, then it begins ... it'll be erected and filled before Chrissy!
Also, paid for materials for house extension. Materials coming in the next couple of weeks. Currently boring the holes for the foundations. Got my 'laser level' and all the cool tricks ready to go.
Anyway ...
all the best in whatever you get up to Joel, I'm sure it's just a semi departure from here, not events hopefully, so hope to try & catch up at the Christmas picnic & dyno days etc.
I've been on the boards for just over a year and don't ever recall any unfair attitude from you, Andrew or Matt........people have to accept that certain issues do require a firm measure of handling otherwise it becomes a free for all. People also have to realize that you guys are partially responsible for a clean reputation of SAU which unfortunately sometimes requires unpopular decisions.
Pete, tomorrow's weather is 24 and sunny (fine). Bringing the beast out to Vilis?
I'm itching for a ride, and may not have time on the weekend, so I'll be riding to work tomorrow and Fri night. :D
BTW found a neat accessory for the bikes Pete ...
Edited by RubyRS4
think you all need me as a mod, im fair and im awesome
/blows own trumpet
on other news, i finally found a 32/36 DGV weber for the rolla :D it comes on a manifold, with adapter plate n all
bargain as well, got it for $80, when other ones similar are going for about $150 on ebay, without all the fruit that is on this one
im stoked to say the least
Almond tree's grow back!! We got one out the front cut down and even the main trunk and roots pulled up a couple of years ago and we're still getting little mini-trees popping up!
Not this one when I'm done with it :D
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
