should bring the gaurds nice and level with the tyres. need new rear tyres though, apparently andrews 34 likes munting left rears. :P
also found out why it sounds so average, non original rear muffler with a harsh as f**k series of bends leading to it, basically 2 90 degree bends where the pipe almost goes flat...
Edited by scandyflick
That and it's an SR.
well... yeah, but i figured that went without saying?
What kinda exhaust you going to go? Cannon or what?
bellmouth dump -> 3" front -> metal cat -> more 3" pipe -> centre oval muffler -> more 3" pipe -> resi -> more 3" pipe -> twin s/s 2.5" drift pipes
bin those damn light covers at the front though muirsky, ive got the cash and o so tempting (went thru this and gtr won last time) however im going investing :P and the shed only got room for 1 gtr
Edited by Inline 6
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
