Over the holidays:
changed plugs and did oil change and coolant change
removed the HKS filter and refitted the stock airbox
removed boost gauge
put Apexi gear up on ebay ... not fitting anymore
removed adjustable and got ride height at 375 front (340 ADR) and 375 rear (340 ADR)
tested exhaust system with cat/box resonator/muffler and its quiet at 88dBA
Should keep the officers happy :P
Also ... I drank lots of beer ... and sold my GSXR race bike :P ... and got a buyer for the Stagea looking at it this week.
I'm approx 380-390 all round... yuck.
wow, and people say im rocking the 4wd spec height.
also, im now home sick. f**k. how disgusting are people that think its ok not to bath and simply cover up their disgusting odour with perfume? had a punter like that today, the smell made me physically ill.
What you going to do then Mitch? Get a motor out of a half cut or full rebuild?
just gonna piss and moan about it for a couple more hours , continue to job hunt , get a job , save up cash , fix it , sell it , move on
but for the mean time , let the car cool down then start pulling the engine apart .
They can be an expensive habit when things go wrong but don't let it get ya down mate!
im trying not to but it slowly is considering how much i owe on the car and all that shit
oh well , least its my car and not my health .
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
