It's a bit sus, Kye. What if the guy on the bike ran into the car? What if he had no reflective gear? Etc.
I wouldn't be riding a bike (or walking) along that road in the first place. :P
anyone seen those flashes of light in the in the clouds up north? is that lightining? on a stinking hot night like this, weird!
YES!!! i did! everyone else thought i was crazy. It wasnt a big enough flash to be lightning tho.
i used to skateboard with that guy back when i lived in the states. hes a twat to say the least but a good rapper. his real name his mohamond.
Haha - you know about Terry Kennedy and his diss track to Lupe? "Kick Push Pass".... its all documented in one of the Beef series (number 4 I think) but I think its funny as hell - they interview a bunch of skaters and say 'all lupe did was a little ollie at the end of his video'
-D
Aaaaaaand that GTR was imported via J-Spec Imports a very short time ago... like... either weeks or months. I remember seeing it on the site, and then that guy buying it and posting pictures.
The rims do nothing for me!
Edit: that ARC airbox is crazy... and is that a hard piping kit leading to the radiator?!
Edit #2: Here's his original importing thread! http://www.skylinesaustralia.com/forums/Im...ey-t217533.html notice how the plenum and timing cover have been repainted? and removed the pods? Hmmm. Not saying it's bad, just pointing it out.
Edited by CRoNic...
Haha yeah!! Did you read about his issues he had during compliance, too? Crazy stuff. But that's importing for you!
Edit: and the actual car only cost $13,405! Decent 32 GTR's (non-v-spec) over there are what... 12-14k before you even factor in the rest of the costs!
Edited by CRoNic...
That was so foul, no one bought it for even $4K :P
What is it with these fools who do up Magnas? :blush: I saw one the other day lowered to all hell, with dark, dark tint and loud exhaust. Don't these fools know they're not a car you bling!?!
I owed 3 Magnas and I never did any of that shit ... waste of money!
Edited by RubyRS4
