It's a bit sus, Kye. What if the guy on the bike ran into the car? What if he had no reflective gear? Etc.
I wouldn't be riding a bike (or walking) along that road in the first place. :P
anyone seen those flashes of light in the in the clouds up north? is that lightining? on a stinking hot night like this, weird!
YES!!! i did! everyone else thought i was crazy. It wasnt a big enough flash to be lightning tho.
i used to skateboard with that guy back when i lived in the states. hes a twat to say the least but a good rapper. his real name his mohamond.
Haha - you know about Terry Kennedy and his diss track to Lupe? "Kick Push Pass".... its all documented in one of the Beef series (number 4 I think) but I think its funny as hell - they interview a bunch of skaters and say 'all lupe did was a little ollie at the end of his video'
-D
Aaaaaaand that GTR was imported via J-Spec Imports a very short time ago... like... either weeks or months. I remember seeing it on the site, and then that guy buying it and posting pictures.
The rims do nothing for me!
Edit: that ARC airbox is crazy... and is that a hard piping kit leading to the radiator?!
Edit #2: Here's his original importing thread! http://www.skylinesaustralia.com/forums/Im...ey-t217533.html notice how the plenum and timing cover have been repainted? and removed the pods? Hmmm. Not saying it's bad, just pointing it out.
Edited by CRoNic...
Haha yeah!! Did you read about his issues he had during compliance, too? Crazy stuff. But that's importing for you!
Edit: and the actual car only cost $13,405! Decent 32 GTR's (non-v-spec) over there are what... 12-14k before you even factor in the rest of the costs!
Edited by CRoNic...
That was so foul, no one bought it for even $4K :P
What is it with these fools who do up Magnas? :blush: I saw one the other day lowered to all hell, with dark, dark tint and loud exhaust. Don't these fools know they're not a car you bling!?!
I owed 3 Magnas and I never did any of that shit ... waste of money!
Edited by RubyRS4
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
