I think that we have established this.
I have removed everything that i have posted that is against rules, and apologized to Madaz.
Dont think anymore can be said apart from,
anyone else getting a really cool breeze around their place?
I dont think an apology is necessary. Im torn between both rules. I'm always one for speaking my mind. If I get told off, I cop it on the chin. I appreciate warnings about dodgy business, same as I enjoy hearing good results from the reputable ones
-D
Edit : I don't just like playing the devil's advocate. Sometimes I like to play the devil.
Edited by Dohmar
you dam hip?
WHAT ABOUT YOUR BOTTOM END?
of your car that is?
Fix.....
ughhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
every where i go , tells me fkin different things and different prices
sick of it
SICK
OF
IT
what movie are you guys talking about?
That adam sandler movie (think its big daddy) where they have rob schneider as an illiterate handyman. they get him to say 'hippopottamus' so he learns enuff english to stay in america and he says.... 'hip..... hip.....hiphop....hiphop anonymous'
was funny. f**k know what the GOAT reference is.
Unless its a reference to the Canibus vs LL Cool J rap battles/beef (Greatest of all time is what LL claimed to be, Canibus said he should change his name from GOAT to GLOAT, to stand for the 'Greatest Loser of All Time'
-D
Edited by Dohmar
Guest CleanAndSimple
You will actually piss yourself quite hard if you have the same sense of humor.
Best Quotes From Movie
Obviously " GOAT! GOAAT!"
"Did you throw your shoe at me, No?, Certainly looks like it"
"FizzieBubbly"
"Come over here, Her other shoulder is cold, look shes going with it, that means its ok"
HAHA!.
Tell us what you think later tonight (if you have asdl2+)
Or Dial Up tell us what you think tomorrow night . lol
Free Speech Rights & Australian Law
"Everyone shall have the right to freedom of expression; this right shall include freedom to seek, receive and impart information and ideas of all kinds, regardless of frontiers, either orally, in writing or in print, in the form of art, or through any other media of his choice."
not on these boards you don't!
Your so called freedom of rights does not apply on this forum.......only thing that you need to concern yourself with is the rules that the admins have put in place that you agreed to adhere by when registering.
If you don't like it (and this applies to everyone, not just you) move on!
Some posts will be deleted and next time there will be an official warning followed by a short holiday if needs be.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
