Confirmed by Bill at ATS. Turbo is definitely rooted. Needs a rebuild. Taking the Stagea off the road for the turbo. :P
While I'm at it, I'll get the front bumper painted and the brakes calipers swapped. :D
did you get a rebuild quote ruby? what parts are included?
$1800 to rebuild my current turbo with new core and turbine housing better matched/machined for my car.
$2200 for a 3071 built for my car specifically.
or
$150 - $300 to go back to a stock turbo.
or
$1300 approx for a second hand 2530 setup.
$1450 for new GT3071R from CRD.
Edited by RubyRS4
wow 1800 to rebuild? seems the old 2530 setup is the go, i saw that for sale, only 3000k's IIRC.
Yeah well I have a house extension to pay for, so I don't really want to spend $1800. My budget is more like $1200. If it had failed say 2 months ago, I'd have easily spent the money then.
If someone buys my S1 Stagea this week, I'll then have the money for a proper rebuilt/new turbo. :D
Stimulus Info...
This year, taxpayers will receive an Economic Stimulus Payment. This is a very exciting new program that I will explain using the Q and A format:
Q. What is an Economic Stimulus Payment?
A. It is money that the federal government will send to taxpayers.
Q. Where will the government get this money?
A. From taxpayers.
Q. So the government is giving me back my own money?
A. Only a smidgen.
Q. What is the purpose of this payment?
A. The plan is that you will use the money to purchase a high-definition TV set, thus stimulating the economy.
Q. But isn't that stimulating the economy of China?
A. Shut up.
I'm saying it'd be around 3k to rebuild my twin turbo's and steel wheel them!! :D
Ruby, can you take the car there or do you have to take off the turbo and take just the turbo there?
taking the turbo off yourself and taking it there will save
a shitload, obviously.
i dare say the 1800 just covers the re-build only
Yeah, thats with me taking turbos off myself and delivering them.
Hey guys, I'm looking at a few Skylines at the moment. Here's one I'm quite interested in.
http://www.carsales.com.au/all-cars/privat...id=11E6C1973ECE
The owner said he'd go down to $12.5k if I purchased it. I've taken it on 2 test drives, and I am quite interested in buying it. What do you guys think? Except for a Regency check, what other checks should I do?
Bomex kit looks quite different. Judging by the engine bay quality, he's taken more interest in the body rather than the engine! Checked for rust, oil leaks, etc?
What's the Regency check?
There was no rust or oil leaks from what I saw.
The Regency check would be the compliance check.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
    • Thanks guys - I have been overseas for a hectic many weeks , so haven't had time to chase any of these up.  Some of the suggestions are for 4.1 ratio, which I already have, and a 3.5 at Lonsdale, which is also too tall.  Really looking for 3.9 or even a 3.7 LSD, either with M12 bolts. Will look some more.
