Confirmed by Bill at ATS. Turbo is definitely rooted. Needs a rebuild. Taking the Stagea off the road for the turbo. :P
While I'm at it, I'll get the front bumper painted and the brakes calipers swapped. :D
did you get a rebuild quote ruby? what parts are included?
$1800 to rebuild my current turbo with new core and turbine housing better matched/machined for my car.
$2200 for a 3071 built for my car specifically.
or
$150 - $300 to go back to a stock turbo.
or
$1300 approx for a second hand 2530 setup.
$1450 for new GT3071R from CRD.
Edited by RubyRS4
wow 1800 to rebuild? seems the old 2530 setup is the go, i saw that for sale, only 3000k's IIRC.
Yeah well I have a house extension to pay for, so I don't really want to spend $1800. My budget is more like $1200. If it had failed say 2 months ago, I'd have easily spent the money then.
If someone buys my S1 Stagea this week, I'll then have the money for a proper rebuilt/new turbo. :D
Stimulus Info...
This year, taxpayers will receive an Economic Stimulus Payment. This is a very exciting new program that I will explain using the Q and A format:
Q. What is an Economic Stimulus Payment?
A. It is money that the federal government will send to taxpayers.
Q. Where will the government get this money?
A. From taxpayers.
Q. So the government is giving me back my own money?
A. Only a smidgen.
Q. What is the purpose of this payment?
A. The plan is that you will use the money to purchase a high-definition TV set, thus stimulating the economy.
Q. But isn't that stimulating the economy of China?
A. Shut up.
I'm saying it'd be around 3k to rebuild my twin turbo's and steel wheel them!! :D
Ruby, can you take the car there or do you have to take off the turbo and take just the turbo there?
taking the turbo off yourself and taking it there will save
a shitload, obviously.
i dare say the 1800 just covers the re-build only
Yeah, thats with me taking turbos off myself and delivering them.
Hey guys, I'm looking at a few Skylines at the moment. Here's one I'm quite interested in.
http://www.carsales.com.au/all-cars/privat...id=11E6C1973ECE
The owner said he'd go down to $12.5k if I purchased it. I've taken it on 2 test drives, and I am quite interested in buying it. What do you guys think? Except for a Regency check, what other checks should I do?
Bomex kit looks quite different. Judging by the engine bay quality, he's taken more interest in the body rather than the engine! Checked for rust, oil leaks, etc?
What's the Regency check?
There was no rust or oil leaks from what I saw.
The Regency check would be the compliance check.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
