OoOoOo!!
The trailer I seen for it had two cars speeding up to a truck hauling 4 petrol fuelages. The cars did 360's and latching there carsin reverse to the petrol tanker fuelages and then stole them from him and then the truck rolled over and blew up!!
OMG that is sooo realistic bro
WOO HOO. nearly got my 1996 hilux tray top 2.8 d should be good to go by tonight, on the way back i got pulled over by the police in the skyline.. was rather pleasant.. they gave me a formal warning for my p plate having fallen down and then i continued to have a chat with the other officer about the car.. we had a bit of a chat about sau and he proceeded to say something along the lines its good to see clubs doing something constructive rather than some of the "commodore" clubs around. asked about my semi slicks and things like that but generally a nice run in with the officers. + 1 to holden hill po po
some say imports are targeted by police, i suspect not.
awesome dude! Even if u did get defected, you would have just canceled rego and stripped it for dedicated track :)
lol its always good fun paying out the fast and furious series lol
btw damo you only have 4 teams in your dream team league or whatever footy thing u got going lol
Edited by Krishy
I know, not much interest! When it gets to the deadline they fill the league with randoms.
well then thats a bit f**ked up then
so common SAU footy fans get into it mate
i dont even follow footy and i am in there.....
you never know might learn a bit about another sport or soo
Main Street, Mawson Lakes. If you come up salisbury highway (from West) then turn right onto the bridge (opposite enffue), go over the bridge (which goes over the interchange), turn right at the lights, follow the road about 200m, its opposite Cafe Primo.
http://maps.google.com.au/maps?f=q&sou...x_HFDA&cd=1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
