^ I propose Damo leaves the link in his sig :P
was there really a need to whore up this thread. Leave it be, report it and let mods take care of it, was there really a need for 9 pages of rubbish?
Oh without a doubt, some very valid points were made, and I think we're actually getting somewhere with the issue.
Wait, what? :sick:
Edited by AndrewJZX100
This "IBTL" bullshit is getting out of hand. Its about time you guys quit whoring the forum for the sake of getting your post counts up. You do realize that every post you put in gets saved on a server, and that storage costs money.
Seriously. How bored are you folks?
-D
I actually agree that posts containing nothing more than '+1' or 'IBTL' or something to that affect are utterly pointless, but having said that, humour is many things to many people, and it seems a fair chunk find the occaisional offhand comment with nothing to do with anything (even less so to do with the actual topic) to be quite humourous. But yeah 9 pages of such is pushing it :sick:
LOL. If that was funny. Remind me not to hang out with you guys on a lazy sat night then. :P
That's what the wasteland is for, useless dribble. If some moron comes on here and doesn't read the rules, there's no need to whore up that thread too. Just makes our jobs as moderators harder and as Dohmar said, server costs add upp too with data storage and traffic. In the end, it's just pointless. The original poster copped a 1 week ban, hopefully we will see an end to these stupid "For Sale" threads soon because I know we are getting sick of removing them!
LOL. If that was funny. Remind me not to hang out with you guys on a lazy sat night then. :sick:
Pushing it... TO THE BRINK OF AWESOMENESS.
Actually I have found something that thread was lacking :P
How could we overlook the loljesus pics?!! :(
Bah the server is huge no doubt, 9 pages won't kill it.
So why is there 1028 pages of wasteland, and the old crap no one reads hasn't been deleted?
and yet people kick up a fuss about 9 pages that get removed anyways..
lol
/end rant
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
