Yeah he said that Royal Purple is really good but heaps expensive.
I would be able to get this oil at cost price cos I work with him, that the main reason why im interested in its performance.
I use Royal Purple in my car! :P
might give RP a go when i do my next oil change. maybe. but i can get 300V at cost... so ill probably just use that again.
Take Gillies advice from the Castrol commercial:
"Car's don't need to be warmed up. Just turn the key and away you go."
Good on ya, Gillies. I'll take that sound advice from such a knowledgeable man.
Does anyone here use ULX 110 Oil??????
Yep I know the oil and the state distributor who I worked with at Adelaide Engine Service many years ago.....good stuff.
It's not actually made here, it's imported from the US and blended then bottled here.
I don't use anything else....but stick to the regular change intervals suggested by your owner's manual.
Just quietly.....I think Troy was living under a rock in the USA :P .
Seriously though, many Top Fuellers use it and reputable dyno shops sell it, ie: Boostworx, Hi Tech Dyno, Graham West, and I think TurboTune (not sure on that one) etc etc.
Not to mention Adelaide's own Marco in the Keith Black powerered '57 Chev.
Sorry Pete? Couldn't hear you. My hearing is still damaged from that top fueller :P
on a slightly different note, this what I posted in that last thread that got moved to the Mods & Admins discussion area before you all had a chance to view it.
Normally I'm a little more forgiving than Andrew but due to that 9 page effort a little while ago (1/2 of it full of IBTL's) that pissed me off, I distinctly remember saying that I'm over reading pages and pages of that crap.
Hence why all 3 of you would've got an official warning but Andrew beat me to it and has obviously let you off the hook.
EDIT: Ripp3r, you've obviously just joined recently to flog your dirty wares me thinks and unless you've been hiding under a rock all your life, you should know better that to try and flog this kind a crap on a public forum, so regardless of Nightcrawler's leniency, you will not be escaping the banstick.
I won't bring up the names of the other 2 now cause I think you got the message.
go on, you know you wana let em jon the "20%" club with me :P haha
that's right you were with me.....yeah my hearing has never been the same either :P
You going to be lurking about tonight? Vilis? BP?
... perhaps even the SMASA show tomorrow? :P
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
