reminds me of the jjr ebay special screamer, big mistake!
260 for screamer
400- labour to fit by un-named workshop (now closed :P)
only had it on for 2 days as the thing sounded sooo bad! like a tractor tbh
Hrmm... how about these??
I wish! AFAIK Tomei don't make dump pipes for RB25DET, so it's OK for scandy. About the only Japanese dump for RB25DET I could find is the HKS and they're nearly $AUD600 (which will almost get me a AM dump/front and hi flow cat). Then you need a front pipe!!!! I got quoted $550 for the CES pipe
As I mentioned before, I can't find one single review (RB25DET) on the internet for the dump/front made literally up the road from me by Advance and sold by Sinergy Motorsport.
ever heard of the macro setting it looks like this
macro image will come out crystal clear depending on camera from 1cm away
flower400x2ga6.th.jpg<<click
that picture was taken with my Tz3 7mp from maybe 5cm away and in the bubble area that was digitally zoomed with paint shop pro 400x
Hey Guys / Gals,
Just wanted to say good on you all for the massive presense of import cars in Adelaide!!!!
Im here on a business trip from perth, and Adelaide takes the cake for import central!!!
In two days ive seen many R33 2 and 4 doors, R34 2 and 4 doors (one four door with SOOO MII as the plates) Evo's WRX's MR2's everything!
Keep up the imports!! Its always comforting to see the familiar sights of round taillights!
So..... I kind of went and put a deposit on a new daily tonight. Pretty over driving the Hilux around, wanted something a little more luxury. This is what a got, should have it in my hands next week.
:P
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
