FFS, my RB20 does not like stock bovs and I've got no fking idea whats causing it :dry:
It struggles to get to .4 bar at full throttle. With the bov blocked it makes .8 no worries. Also of interest is that the bov doesn't open properly when it's plumbed in. Opens briefly at full throttle but still flutters like mad otherwise, like it's not even opening. My old 32 would NEVER flutter with the bov plumbed in, like it opened even backing off at 0 boost.
On the plus side it seems pretty controllable to slide, even on stock sus with a weak viscous diff :P
Edited by AndrewJZX100
anyone got a ute/van/wagon etc and wanna earn $20 ??
i need to take my un-assembled bottom end to turbo tune and i dont have a working car !!
reply here or pm me or call me 0419848600
willing to pay more if you have to travel !
could be a leak on your BOV by the sounds of things andrew....
try another stock BOV if you can get your hands on it mate..
Thats what I thought, so I did just that and it does the same thing :dry:
Stock RB20 one does it and stock RB25 s2 that I just bought does it as well. I'm thinking maybe a vac line somewhere might be a bit suspect.
i would say that if its making the right boost when the BOV is blocked off then just leave it blocked off....Flutter FTMFW
but now it sounds like the vac line from the BOV to the plennum is leaking or something strange is happening
let us know when you find out what the problem was mate
good luck
PS flutters man leave it fluttering lol
PM sent
Not real keen on the flutter hey :P
Well, not all the time. Sometimes it's good (like driving through Mt Barker around 3:30 on a school day :P ) but yeah mostly it's just annoying.
What are you doing near a school andrew....specially on a school day :dry::P
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
