hmmmm Garrett T51R with 6 boost manifold
*squels like a little girl*
me likies ;)
youve conformed?
youre less cool than you were when you were supercharging it.
:P
Edited by scandyflick
whats everyone up to today?
Work ... and lots of it. :P
Both my admin assistants are off today, so I'm in the office alone.
yeah keep me in mind in 5yrs time if you part with it.
always wanted a v-twin, and the TLR would suit me nicely
mind you, an rsvr aprilia Mille or honda sp1/sp2 would be interesting as well
The Mille is still too pricey imo. And I've ridden an SP2 ... you won't like the cramped riding style and the frame flex under abuse. Brakes are good tho. But I've got Brembos on the TLR now which are far better.
youve conformed?
well considering i found out i was lied to about the rear wheel power figures with the 850hp blower, the other two options were to a) go to a 1200hp blower which would cost me $4500 on its on (then on top of that would need belts, etc) or b) go turbo
now as much as i dont want too :P
im seriously considering the T51R as my turbo of choice, it has also been recommended to me by Sam at Chris Milton Engines, ill be going with the 1000hp one, which also means going RB30 bottom end, (dont have a choice).
but at least i know ill definetly be able to make my minimum power of 500rwkw :P aqnd if i wanna driver her on the street, i can just put her on low boost :D kinda works out good i think lol
and :) to you to dave :P
hahaha join me for lunch?
i cant believe that i will be staying here tonight as well......and i thought Naracoote was bad enough sheesh
ahh well
there, there,
there, there krishy. youll be fine ;)
ner ner i got day off :)
now as much as i dont want too :)
but at least i know ill definetly be able to make my minimum power of 500rwkw :P aqnd if i wanna driver her on the street, i can just put her on low boost :P kinda works out good i think lol
and ;) to you to dave :P
how many people did it take to convince you that the power output you were expecting was simply too much for the supercharger you were going for?
why the hell you need 500rkw in a state that doesnt have a drag strip is still beyond me though.
wait, i forget, isnt sam the one who said *insert stupid power figure here* was achievable on that tiny little supercharger too?
bah, sad panda spec, another 2 days until i get the 200 back on the road. :D
i dont intend to drag her dave, im not building for that reason.
and sam wasnt the one who said about the power figure, the dude at capa was. he originally said i could get 500rwkw, then when i re questioned him about it, he has said 300rwkw.
look im happy to spend the money i will be spending on my engine to be built, but by hell, i will not let a engine that is capable of 500+ go to waste with something that is only gonna help me make 300rwkw.
who you gonna perve on all day now :P
its month end here and i got uni assingments to do ;)
and i think cara just likes to stir people with these posts of options, next plan v8 in the 34.....its been done cara
Edited by Inline 6
id put a v8 in the s14.
wide body, potato potato LSx, fat meisters, and the ability to stab the clutch in any gear and turn the rear tyres into smoke. awesome.
should mention that heslo disagrees with this idea rather strongly. :P
is it worth dropping 30k on an engine for it to get some numbers on a screen? i mean the only people that respect dyno queens power outputs are other dyno queen owners, or 12yr old boys?
**yes yes, i know horses for courses but im just tryna get my head around it
*** why not just spend that money on some crazy wide body kit, massive dish wheels and more vynil?? or do you really just want a autosalon dyno trophy?
Edited by rhys5169
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
