:laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
when i went downstairs to check offsets and what not, i noticed roo was typing. came back upstairs and he was still typing... hmm, hang on a sec. refresh, new post in the wasteland, one from roo oddly enough. first thing that came to mind;
rick roll.
check the link, oh you sly dog...
... ruby, you officially just became awesome again.
What? :dry: Its the quiet ones you gotta watch out for. Andrew, you shoulda known better. ;) See y'all when I get back from my holiday. :D
Edited by RubyRS4
How do I get the text below my avatar pic changed to SAU:SA #1 :dry:
Huh?
You, QUIET? bs.
By that I mean I'm more subtle and less suspect than Scandy :D
Edited by RubyRS4
Just looking through ebay and found this, VP commodore styles much!
*looks a rear wheel arches* .... *Runs to vomit*
that is f**king horrid, bogans should have to pass a test before taking ownership of skylines.
tis in profile - custom member title
Thanks :dry: Thought it was something simple ... I went right past it ;)
Oh dear ... I don't appear to be popular on ns.com for the rick roll :D
What compels someone to do such a thing is fkn beyond me! Pay to make your car look shit, nice concept hey!!!!
you were never popular there in the first place.
... did you just make it worse?
Of course not ... much. :D
Why so serious?
edit: Hey, hey. I just got a ban from ns.com for the rick roll :dry:
Why so serious?
i think they banned you for the blue mesh and the wheels. the rick roll just gave them a legit reason to do it.
... just sayin.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
