I think you'd be dumb to change engine from non turbs to turbo. I'm pretty sure there is more than a brake upgrade as well, things like suspension would have different spring rates and the dampers would be different as well. As a turbo engine would weigh more than an NA.
Like people have said 34 GT-t has a stronger box than standard GT, diff is different, tailshaft as well, etc, etc.
What happened to the supercharging idea?
when importing.. do i get to choose out of a couple of cars which one i want?
do inporters shop for what i want?
like specific body kit, auction grade etc?
people like chef, if you give him a ruff idea on what you want and how much your wanting to spend he would look out for something and give you lists on what he has found till you are happy.
i personally know 4 people who have bought off him and they were all happy with the outcome.
same goes with jspec. they were giving me email updates on things that they had found that were similar to what i was asking for.
I don't know the in and outs of it all but regardless it's a waste of time anyhow!!!
ah not really a waste of time
I think you'd be dumb to change engine from non turbs to turbo. I'm pretty sure there is more than a brake upgrade as well, (1)things like suspension would have different spring rates and the dampers would be different as well. As a (2)turbo engine would weigh more than an NA.
Like people have said 34 (3)GT-t has a stronger box than standard GT, (4)diff is different, tailshaft as well, etc, etc.
(1) think you'll find there pretty much the same its cheaper to only do the R&D once
(2) how much does a turbo and inter cooler really weigh :( so your not adding much extra weight there
(3) gearbox is only 2 sorts RB20 and RB25 so i think you'll find there the same
(4) yeah pretty much same
realistically you don't save any money making all these parts for non turbo cars
Yes Dre you get to pick and choose everything once you get Kristian looking for a car you become his boss he is your employee, but don't be and asshat about it because he may say your too fussy and suggest another importer for you to try :(
wasnt delivered through aus post. was delivered through fastway couriers, according to the calling card i have to wait til monday. no biggie.
Edited by scandyflick
ill just leave it til monday. got work tonight, and ive gotta get the exhaust and such refitted to the 200 tomorrow, and spend the afternoon catching up with a couple mates.
so monday it is. lol.
So that means my car was a waste of time aswell? me and a lot of other people think that engine conversions aren't a waste of time.
AWD, RB26DETT in a car that looks like a GTST, FTMFW! :)
What the f**k is so good about the brand Ed Hardy. ? Looks like childrens clothing.
yeah, i havent figured that out either. i dont get what the big deal is in paying $100 for a shirt that looks like 5 babies threw up on it.
guess im just not hip enough for that shit.
whos ed harry?
AWD, RB26DETT in a car that looks like a GTST, FTMFW! :D
what about a 33 4door with a rb26dett thats still badged as a non turbo :)
im really liking this car but it runs rich as all hell atm :(
lucky your pockets aint empty cuz :)
riches get b*tches
n chad we all know rb26s in old school dato's are the way for ultimate sleepers :D
bogans cant tell the diff's in skyline models, wouldnt know what gtr is. but everyone thinks a dato would never go fast :(
Edited by Inline 6
dude, go tell that to every other person out there that does engine swaps in cars.
(2) how much does a turbo and inter cooler really weigh :) so your not adding much extra weight there
thanks steve, ive found when getting stuff for the 34 that most of it is GTT anyway. and i have done most of the stuff anyway that i would need to do (like ecu and brakes) there shouldnt be too much stuff i would need to get i dont think.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
