yeah, im starting to get pretty disheartened about it all really. :)
as of today is been 4 weeks since its moved (and has cost me over $400 in loan payments and insurance for the privilege, and the parts on top of that). im about 3 seconds away from taking to it with 10 litres of petrol and a match.
ive called andrew and left a message, im having trouble seeing how 3 components designed to fit an s14 dont work together. its doing my head in.
i shouldve just used the gktech gear. wouldve been back on the road over a week ago if i had.
Edited by scandyflick
Push it in, make it fit. push the catback out as hard as you can?
tried that. even with the catback pulled back as far as it'll go (with ZERO play left in the hangers) the gap is still about 5mm too small fit the bastard in. add another couple mm for gaskets and yeah, shit just aint gonna fit.
PLEASE dont take it to AAA Andrew is @ supercup today and will be more than happy to help sort your shit out
BUT sounds like the apexi is whats giving you grief, how is the factory cat 30mm too long :blink: i would of though the factory cat should be the right length
yeah, i left a message on his phone. figured he'd be at dsc. both cats are the same size (factory is a couple mm larger than the xforce one), both fit fine with factory dump and front, neither fit with the AM pipe fitted, the gap between the rear flange on the front pipe and the front flange on the apexi is 30mm too short, which makes me think the front pipe is 30mm too long.
ah well yeah wait till he can sort you out becuase you've paid for his work and now he wont rest until its sorted but if you take it somewhere else and they butcher it then you need to take it back how bad will that be
yeah, i just feel like a bit of an asshole taking it back, ive already had to take it back once eh...
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
