you know whats awesome?
graphics.
... and sarcasm.
yes i know my graphics are awesome thanks dave :cool:
and yes, dan is quite good at sarcasm too
maybe i should get some fully sick dragon graphics for the rolla? :)
the following tests will be carried out,
0-400m sprint, self explanatory really. test will be held at anzac international raceway.
the shopping test, leave both cars parked at tea tree plaza while the owners shop for 2 hours and come back to load their shopping into their cars, points are awarded for the most shit squeezed into the cars, and points are deducted if the car has been vandalised/stolen/laughed at.
the hindley test, a saturday night hindley st lap at 10pm. points will be awarded for the amount of positive looks (smiles, nods, thumbs up, etc) a car receives, and deducted for negative looks (laughs, obscenitys yelled or implied, etc).
the maccas tests, standard maccas drive through with 2 people ordering in each car, points awarded for not scraping wheels, not having to lean out of the car, etc. test will be held at ttp maccas.
the defect test, each car will go through a defect station, points are awarded for getting through unscathed.
the winner will be awarded 1x internet.
Edited by scandyflick
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
